Question about ASUS DRW 24B1ST Disk drive DVD RW ( R DL) DVDRAM 24x24x12x Serial ATA internal 525" Burner
It says my DVD is working properly but I cannot open the drive....I manually opened the drive and I can't close it without doing manually also. the light comes on but it is not responding.
  • ASUS Master
  • 629 Answers
Check the dvd drive and see if there is any damaged on its plastics that may cause the issue. make sure the drive tray is not being stuck and nothing is preventing it from opening or closing. next, try to remove and reconnect its power and data cables. Using different cables if available may also help. if using the eject button works, but not through the OS, a possible reinstall of the driver, the firmware and even of the OS may be necessary. if all else fails, there is a chance that you may need to get a drive replacement.
Posted on Sep 05, 2010
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a dell laptop and a DVD is stuck in the drive
You will see a tiny hole in front of your dvd drive, it is usually beside the light indicator, deep in a pin into it and the drive will open even without the laptop being on.
Try it, it might help
I wish you the best.
Nov 13, 2009 | Dell Latitude D610 Notebook
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
My DVD drive does not open
Yes, there is a manual way to open it. On most DVD players there is a small hole underneath the door. Push a paperclip in there until the door pops open a little. Then, pull open the door and remove your disk.
May 29, 2009 | Philips DVDR 520 (DVDR520) DVD+R Storage...
DVD tray automatically opens and closes
Is the drive reading disc properly? if no then just change the drive.
If it can read disc then
1) Do an msconfig & disable startup - just to make sure that there are no pesky script or applcation doing it.
2) change the SATA port on motherboard or toogle between master & slave if IDE cable is been used.
Still if its not working then just change the drive.
Nov 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell3000 dvd drive will not eject if loaded
it is a normal problem i dont think it has ne problem
Nov 16, 2008 | Dell Dimension 3000 PC Desktop
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
I suggest you may have accidently put another disk in your DVD drive on top of the one used previously without removing it first: I know, I did just that, and the teeth may now be sheared on the drive wheels which means it will probably need replacing with a new one.
To open manually, look for the tiny hole beside the Open/close button just under the drawer and insert a long slim steel probe which will activate a switch to open the drawer. (Have a look among your kitchen utensils, there might be something there).
Hope it works, but you may find you need a new DVD/RW unit, so have a look around in the New Year Sales and use the opportunity to buy the best you can find at a bargain price.
Raydot
Dec 16, 2007 | Philips DVDR 520 (DVDR520) DVD+R Storage...
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
ASUS DRW 24B1ST  Disk drive  DVD RW ( R DL)  DVDRAM  24x24x12x  Serial ATA  internal  525"  Burner Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
