Question about Brother LS-2125 Mechanical Sewing Machine
How you you attach the quilting foot?
Pleas help i dont know how you atatch the quilting foot
  • Brother Master
  • 1,388 Answers
If you don't have a manual to show you, you might phone your local Brother Dealer where you bought the machine & foot and they can guide you over the phone, or arrange a time for you to pop in and be shown........if this is not convenient, Brother HQ in your country should be able to assist or give guidance as to where to find a solution.
Posted on May 12, 2008
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
1/4 Quilting/patchwork foot w/attached shank for Pfaff #1221 available?
Check with your local Pfaff dealer for a 1/4" quilting foot. OR, search the internet for Pfaff presser foot.
Nov 10, 2015 | PfaFF Sewing Machines
Quilting and patchwork foot with attached shank
Probably, but since we don't know the model, we can't help you much.
You can search the internet for your make and model machine and search for a 1/4" presser foot. You'll most likely find one piece presser feet or even snap-on feet where you purchase the shank adapter and then separate presser feet that attach to the shank.
You can also check with your local Pfaff dealer.
Nov 08, 2015 | PfaFF Sewing Machines
How to fix squeaking Bernia walking foot?
I would oil the foot with sewing machine oil where it is attached to the fitting. Be sure to then run the foot on a scrap for awhile to remove any excess oil.
Jul 26, 2014 | Bernina Sewing Machines
Bernina Binding Foot
check on youtube for a video
Aug 20, 2012 | Bernina Sewing Machines
I have just started learning how to quilt and I was told I needed a walking foot to quilt the sandwich together. I purchased one today, but I don't even know how to attach the foot. I also need to...
The foot is attached as normal, but when you're attaching it, the fork-shaped part that sticks out of the right-hand-side has to be hooked around the round pillar sticking out horizontally from the right-hand-side of the needle bar and that holds the needle securing screw. When the foot is down, you will see that the upwards motion of the needle bar raises the upper set of feed dogs on the walking foot - the whole purpose of the walking foot is to provide, effectively, a set of feed dogs on the top of the material as well as the toothed ones below the stitch plate - this allows multilayered or thick materials to be sewn as when doing quilting.
Jun 30, 2011 | Bernina Activa 130
Attaching quilting foot
Can tell you how this works on my sewing machines that have the snap-on feet.
You have to remove the adapter for the snap-ons and then the attach the darning/quilting foot with the screw that holds the adapter to the shaft.
Apr 29, 2010 | Janome Memory Craft 4000 Sewing Machine
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Feb 04, 2010 | Husqvarna Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
113 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
