Question about Garden
I have philips QHF560 sensor floodlights installed outside. Inside there is a normal light switch which can turn it off or on. There is a certain way of switching it on so it will either operate as a sensor light and go off after a period of time, or stay permanently on but I can't remember how to do this.
SOURCE: electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Posted on Jul 28, 2007
Fixer here
  • 29 Answers
SOURCE: open door light stays on on dashboard - ford puma
The contacts of the sensor to the Door can be dirty. Thus it can't sense the door properly and remarking open. Also there is a solenoid behind the Door which can be defective which can cause the problem. Kindly call a technician and check the parts.
Thank you Sir, Have a nice day.
Posted on Sep 28, 2009
  • 166 Answers
SOURCE: Tiburon 04, left turn signal lights stay on
replace the turn signal 'Clicker' also known as the turn signal relay. Most likely the problem unless you have a really wierd electical issue that will be hard to isolate...
Peace,
Posted on Mar 03, 2010
  • 80 Answers
SOURCE: backup sensor problems
easiest way withoout a scanner is
verify that all wire connectors to back of sensors are not noticable damage, if so repair
if no damage, buy one sensor and trial each one with known good one til light is functioning properly.
very common for sensors to fail, so if want to fix you will need to buy one and all are the same so you can inner change
otherwise you will need scanned to determine which sensor is faulty
hope this helps
Jay
Posted on Jul 27, 2010
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
Posted on Nov 23, 2010
To turn on at dusk, and off at 9:00PM, 14 outdoor floodlights from a central location, by wireless means, 200 feet apart, through concrete walls;; L,Hayet@att.net
1) Install 14 z-wave switches or micro-switches ( one inside each light switch box) and control all 14 switches using vera lite
Set scene for times you want
Install repeater modules to by-pass distance and concrete-wall problems
http://www.amazon.com/dp/B008VWBNAU/?tag=waterheaterti-20
http://www.amazon.com/dp/B0035YRCR2/?tag=waterheaterti-20
http://www.amazon.com/dp/B007005364/?tag=waterheaterti-20
Note: Z-wave gets expensive and is complicated.
Rule of thumb... if you like messing with all the buttons on your TV remote control, you will love z-wave.
Resource explaining roughly what z-wave is about
http://waterheatertimer.org/How-to-wire-Intermatic-CA3750.html
2) Cheaper solution... but no remote control... is to install a programmable timer in place of each light switch.
Additional problem is ON at dusk and OFF at 9 pm.
http://waterheatertimer.org/Programmable.html#st01
Gene
Oct 23, 2014 | Hardware & Accessories
Sh5412. The red lite blinks when walking past but the spot liters do not come on. The test was ok
What test did you do? Did the floodlights come on with the sensor switch in the Test position? Did you wait two minutes after turning the circuit on? Is the sensor in the dark? If your answer is yes to those questions, then try the following:
Double check the wiring. Sometimes a wire will come loose if the stranded wire from the fixture is wrapped all the way around a solid house wire. The solution is to gently bend the bare tip of the solid wire in a soft s shape so that the stranded wire does not completely wrap around the solid wire when the wire nut is twisted. (I know that you said the sensor red light is coming on but the additional load of the floodlights' current may not flow if there is a loose connection, very little current needs to flow to operate the sensor.) (The wires should be connected something like this -White from house to white for sensor (and to whites for lights unless this light connection is done internally in the sensor by Heath Zenith), Black from house to sensor, Other colored wire from sensor to lights (again unless this light connection is done internally in the sensor by Heath Zenith)- Also check that the spotlights are not burnt out and that they are tight in the sockets.
http://www.heath-zenith.com/servsup_instvideos.htm
Oct 22, 2014 | Heath Zenith Secure Home Motion Activated...
Does anyone have the instructions which come with a micromark MM18033 500W Floodlight and WIREFREE PIR SENSOR? Thank you
Yes.
e-mail me at iclarke@rockelectronics.co.uk and I'll send you the 4 sheets f.o.c.
Sep 29, 2014 | Electrical Supplies
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Hi Ive got a Lutron Grafik Eye 3000 controlling
I need more information. Are the fixtures pot lights? What kind of bulbs are you using? Floodlights, spotlights, incondescent (normal tungsten filaments) or fluorescent, compact fluorescent, led etc. Since most dimmers say in their instructions that they are designed for incondescent lighting only the bulb you use can either blow up the switch or cause troubles like you are specifying. Also inside pot lights are thermal cutoffs that trip and reset when the light is cool again. Can you remove the switchplates and see where it says incondescent only embossed into the aluminum heatsink? If it says something else, what does it say?
Aug 01, 2013 | Lutron Electrical Supplies
Blue lamp is producing light but no images
IF YOU LOOK IN THE LENS OF RED, GREEN AND BLUE AND ANY LOOK LIKE A FLOODLIGHT (BLUE IS MOST COMMON) THE glycol coolant is contaminated with bacteria--common on Philips sets and not a do it yourself repair--the glycol is like antifreeze and 10 times more toxic--it is meant to cool the face of the picture tubes.
It can be replaced but is not easy--let me know if Blue looks like a floodlight and I will tell you what is involved.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 19, 2010 | Philips Magnavox 51MP392H Rear Projection...
Putting outside lamps on exterior on timer
why not connevct them up to a movement sensor, that way they come on when you make a movement near them. So they dont fire off when cats or birds fly by make sure you set them to close to your height. Then you can see your way to the shed turn the lighjt on that you can now see where the switch is and then turn it back off when you leave. Most of these sensor lights can be set toa timed on period
cheap and easy to install
Jun 21, 2009 | Heavy Duty 872-3301 - StormPro SP3301 - ...
Eerie Orange/Red Glow Inside Floodlights (bulbs)
I think this is by design. Look at the instruction manual and it should tell you. This doesn't make sense that they should be on, but they may have a reason for it in their design. Now to the bulb saver technology thought, you are mostly right here. There is a lot of "strain" if you will on the filament when starting it up and it does cause a weakening over time. You will notice that when a bulb goes out, it usually happens right when you turn it on. The same thought here. I suppose in this device, that a constant voltage (low) is better and more efficient than zero voltage to 120 volts. They probably take into account the sensor will be used several times a day thus making the need for this kind of set up even more demanding.
Mar 02, 2009 | Electrical Supplies
Garden Logo
658 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
