Question about Kenmore Oasis HE 27082 Top Load Washer
What was part number
Thank you for your post on FixYa. I am experiencing SAME F1 error at startup and has now progressed to 17 minute mark! What was the part number that you ordered and where did you order from? Maybe a way to get Sears is to fix all of them ourselves and take away their repair profits? thanks for the info...
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Nov 19, 2011 | Ovens
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code f 1
Hello, our carbio began flashing the F1 error code at 18 months. I have to hit the pause/start 4 or 5 times to get the cycle to begin. It also flashes occasionally at the rinse cycle (17 min.) I have called Whirlpool 3 times with little satisfaction. They have offered to pay for the part, but I will be responsible for the service call, diagnostic fee, and labor. I am not satisfied with this offer. It is obvious to me with so many others experiencing the same problem that Whirlpool has a quality issue with this machine. The sales rep who sold me the machine said to call Whirlpool everyday until they are sick of hearing from me. The more calls logged about the complaint, the better chance of a recall on the machine. If this is not resolved, I will NEVER buy Whirlpool again.
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you
Jul 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 shows on control panel of both drawers,after a couple of startup.Even when machine is not being used both drawers startup on F1,only way to control is to shut off at main supply
Hi
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 17, 2010 | Fisher and Paykel DD605SS Stainless Steel...
Whirlpool Cabiro F1 Error Message
Very glad that you are receiving some assistance from the manufacturer on the this issue. I have assisted many folks with this particular problem and will be interested to see what is done on your machine to remedy the problem. I will appreciate it if you will keep us informed. Thank you.
Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error
there is a factory defect in the control circuit board of this washer, read and call the number. post is from another owner.
I called 800-659-7026, which seems to be a 3rd party "recall" center for appliance companies, for my F1 error code. All Kenmore HE Elite Oasis machines with Serial Numbers beginning with CS48-CT49 are in the process of being recalled; however the mailings haven't gone out to customers due to hold-ups in legal with wording. Machines with these serial numbers require an upgraded control board and it takes about 10 business days for the part to come in. They ordered it with no questions asked and are coming out July 14th to replace it free-of-charge
Jul 15, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
Kenmore range code f1 e2
F1-E2 - UL A/D Error(s) - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 05, 2008 | Kenmore 72002 / 72004 Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
