Question about Garden
How do you fit a bosch rotak 34 lawn mower drive belt?
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
Posted on May 01, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
How do I remove the cracked positioning lever from Bosch Rotak 34-13 lawnmower?
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Jun 22, 2016 | Garden
There is a crack in the positioning lever of my Bosch Rotak 34 lawnmower. I have located replacement but how do I remove the old one?
grind off the rivets that hold it in place and use bolts to fasten the new one in place .
I cannot see how this is mean't to store away to 55cm Bosch Rotak Lawnmower 34-13
perhaps you need to go to the place that sells them and ask . looks like the handles removes easily to take up less space is all you can do .
Aug 24, 2015 | Garden
Manual for bosch rotak 36 mower
contact the seller or go online to Bosch to see if they have extra manuals posted online. Or ask customer service for help.
Jun 06, 2014 | Bosch ROTAK-320 LAWN MOWER FOR 220 VOLTS...
Lawnmower electric
In most cases its not worth to invest TIME if you have a rotak 40 or so , because of the low quality of Bosch mowers its because of they have take over qualcast brand from England they are now owner , the last years there are mowers that have a belt drive from electric mower ROTAK i have replaced a belt but its takes so many thinking and working time to split and rebuild after that the bearings are also not fresh enough to let it be whats over when its over with the bosch mower get an other brand I've never been in working misjudged restoring so, one machine mainly perform the standard excess tension on the belt which the bearing to excessive heat, the stuff is made to break down. i have this year 20 years behind me in repairing also Bosch powertools and thats not only the problem that its BOsch , no its the Qualcast quality that fits the last years inside the bosch brand. the last 7 years the Bosch powertools are differend by model and price and from bad to perfect. but the most common problem is the working time that you will have on a green rotak mower. if you own a old model Bosch fore 8 years ago then the parts are sometimes difficult to get. difficult to place an correct answer but be warned if its handling a rotak .
Apr 05, 2014 | Bosch Saws
I need insruction BOOK for Bosch Rotak 344 GC LAWNMOWER
Here you go:http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/Rotak34_manual.pdf?db=ocsr55_s041&item=OCSHEIMWPDF.v$m$d$lobvalues.r55&id=90005,10446,20&filename=Rotak34_manual.pdf
Just copy and paste that into your browser it will take you straight to the pdf for it.
Jul 03, 2012 | Garden
Reassembly of the "control switch" to Bosch Rotak 40 rotary lawn
Taken to local commercial garden machine repairer
Apr 05, 2009 | Garden
Garden Logo
2,207 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
