Question about Ricoh Cameras
Hi my R50, zoom/lense doesnot close properly, it says "System Error". pls help me out. Ram
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
Machine clicks when turned on and focus is stuck. it sounds like focus gears aren't meshing properly
hi, Zoom/Focus Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
hope this helps
cheers
May 05, 2011 | Cameras
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
DCR TRV30 Zoom in/out Problem
Yikes... I have to say, yikes, since my camera has just recently has the same issue. It's a lense issue. The service men said a lense isnt something to joke around with or try to have just "anyone" to look at. This isnt something you can just fix on your own. You need to notify the manufacturer regarding the OEM manufacturer of the lense. Or, get their information on who to have inspect it. Typically, its something broken, and very small that is articulate and impossible to fix on your own, otherwise there is something off with the focus on the lense..or its creating this issue. Again, dont mess with it it will only make it worse when you hear that grinding sound, trust me..I messed with mine and made it worse then it could have been...
Oct 03, 2007 | Video Cameras
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
Jul 11, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom Error
hi thanks for using fixya!
On this kind of error, I suggest that you bring your camera to a service center or to your retailer to further check the hardware problem of your camera.
Regards!
Apr 30, 2009 | Fuji FinePix A500 Digital Camera
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
170 people viewed this question
Top Ricoh Cameras Experts
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
