Question about Tissot T Touch Navigator 3000 T96.1.488.42 watch
I can't change the analogue hands to my time zone in Perth, West Aust. It only shows the time in Sydney.
Braun BN0087GYSLMHG that is always reading 1 hour ahead of britsh time
Press button B for 2 seconds and second hand will move to show current time zone; 12=London, 1=Berlin, 2= Helsinki. press button A to cycle through time zones till you get the zone you want, then press B to confirm. Summer and Winter are changed automatically, contrary to the previous rubbish....I mean answer!
Jan 10, 2014 | Braun Watches
I want to change time zones on my casio edifice. I can't work it out.
Press the button on the top left-hand side of the watch until the display shows the current hour and the letter "P," "M," "C," or "E" which indicates the current time zone. (Pacific, Mountain, Central or Eastern.) If the time zone is not correct, press the button on the top left-hand side of the watch until the correct time zone is displayed.
Feb 28, 2011 | Casio Watches
When its 2200 on Feb 2 New York what time and date is it in Australia
It depends on where in Australia. The time difference is anywhere from +13 to +16 hours difference from New York. So somewhere between 1100 Feb 3 to 1400 Feb 3.
Here is a list of Australian cities and the time differences:
Australian Capital Territory - Canberra *+16 hours, New South Wales - Sydney * +16 hours, Northern Territory - Darwin* +14:30 hours, Queensland - Brisbane* +15 hours, South Australia - Adelaide * +15:30 hours, Tasmania - Hobart * +16 hours, Victoria - Melbourne * +16 hours, Western Australia - Perth* +13 hour.
I hope this helps you.
Feb 03, 2011 | Watches
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
Cant reset my watch, currently in perth which is 3 hours behind sydney, woul like to have at least the analogue side set to perth time
If you read the instructions you should be able to set your watch so that it reads tha correct time for Perth (on my watch this is achieved by pressing the mode button to enter "world time" - three letters indicating the reference city- and then press the button at 4 oclock to scroll through the alternatives; the setting should be BKK for your time zone)
If you haven't got instructions on how, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 05, 2010 | Casio EFA119BK1AV Watch
I don't have a manual with me, and i need to change the time
Follow this link and get full info:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Mar 22, 2009 | Casio Watches
Silicon radio control watch, what # is the eastern zone
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Dec 11, 2008 | Bulova Watch
Analogue display does not sync with digital
Go to the Casio web site. Download the manual for the watch. Go to the section called "To Adjust the Analog Time." The answer is there, step by step.
Sep 22, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Synchronizing digital time with analogue time
hi...
press the T button until the crystal is activated.
press the middle of the glass until the time format appears (24hb Cm appears)
hold the T button for 5secs (SYNCHro appears)
move the hands until they are at 12 o'clock. ( + button moves the minute hand. - button moves the hour hand)
press the T button to set.
digital and analogue time are synchronised
pol
Jun 19, 2008 | Tissot T-Touch T33759851
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Tissot T Touch Navigator 3000 T96.1.488.42 watch Logo
262 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
