Question about Coleman Mach 15 Air Conditioner
Coleman mach 8333 series won't run. both compressor and blower inop. checked power in 120v,checked blower switch and therm. both are working. what next?
  • 674 Answers
Check the capacitor. You probably have one capacitor that controls both the compressor and fan. If that isn't it, check the contactor and make sure that it pulls in when the thermostat calls for the A/C to come on. Also check the voltage on the line side and load side of the contactor. I have seen some with voltage on the line side but it wasn't making it to the load side.
Posted on Sep 05, 2010
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Trips breaker and will not cool or heat
Disconnect compressor leads and tape them up. Restore power, if the breaker does not trip, than you have a grounded compressor.
If breaker trips again, hook compressor up and disconnect blower, if breaker does not trip you have a
bad blower motor.
Jun 18, 2010 | Coleman Mach 15 Air Conditioner
Compressor does not run. On turning the AC on, the compressor does not run. The blower fan does though. Checking the relay panel, the relay for the compressor does not engerize. a temporary solution is to...
Hi, if you are energizing the contacts on the contactor, and the compressor runs, the thermostat is faulty. This is what energizes the contactor coil that you have. You need to check to see if you have voltage to the coil on the contactor. You need to replace the stat asap.
Sincerely,
Shastalaker7
Apr 16, 2010 | Coleman Mach 15 Air Conditioner
For the 13500 btuh cooling what is the voltage and
you need a 20 amp breaker the full load amps on that unit is 16
Apr 08, 2010 | Coleman Mach III Air Conditioner
Blower inop on auto or manual. burner inop.
Hi check out the fan control afc see if it is clean , check out pressure switch and the flame sencer
Feb 21, 2010 | Coleman Propane Forced Air Heater...
Need printed circuit board for coleman 8333-8715 need part number have 115 vac to board but no out put
Is that # off upper unit or ceiling assy? Need ceiling assy # Here's a link for you to try.
http://www.rvcomfort.com/rvp/service/model.php
Jul 12, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman Mach 15 AC just quit. no compressor sound, no fan
If this is a ducted unit, check the thermostat. It has a fuse for protection that may have blown. If the fuse is fine and you have power to the upper units control box, check for 120V incoming power at the control box and also check for incoming 12V on the Yellow and GH wires when tstat is set to high cool.
Hope this helps.
Jun 26, 2009 | Coleman Mach 15 Air Conditioner
Coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Oct 01, 2008 | Coleman Mach 15 Air Conditioner
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
245 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
