Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
Ballast replacement bought a new lamp for this tv, connector plug did not match the ballast. but found ballast was bad anyway. bought replacement ballest, lamp plug now matches ballast plug, but the old ballast had a three pin connector form the power supply board, the new ballast has four pins. and the part numbers are the same from lg. the actual numbers on the ballast are, old ballast EUC 100 C/00, new ballast EUC 100 P/11. the old ballast has two opto-isolators going to the plug, one in one out, the new ballast has three opto-isolators, one out and two in. got a schematic for the set but does not show the ballast at all, it does show the connector going to the ballast, but its only the three wire one. how do i fit the new ballast in place of the old one? lg was no help at all, they don't even know there was a difference with the lamp plug or the ballast control plug. my dea would be to just tie the two inputs together, but i wonder if this has something to do with start up control. it could cause the lamp to just pop on with out a pre-heat, which would probably kill it. any type of schematic or even a block diagram of this ballast would be a help. thanks dave.
  • LG Master
  • 8,617 Answers
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
Ballast to lamp connection cable melted on one side
The Ballast plug melted due to age of the TV. as the plastic gets old it gets brittle and can crack with barely any force. The pins then do not seat and the arc that should be in the lamp takes place in the connector. I have seen this so many times. fortunately it is very easy to replace the connector is you know how to use wire crimps and can source an old female plug. eBay is a good source. you can buy a used ballast from any model that has the same connector. Then cut off the new plug and splice it onto your old wires with but-crimps and shrink tubing.
Oct 01, 2015 | Mitsubishi WD Televison & Video
Lamp failure in WD-52525
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I replace a new Philips bulb on my HL-R7178W and still not light up. It has humming noice (not hi pitch) and clicking like on and off and the Standby/TEMP and LAMP lights flash 2-3 times and turn off. The...
Hello... I would start by getting the correct lamp for the TV, and I would advise getting an original equipment lamp. The lamps and ballasts are matched by wattage and operating voltage, and a mis-match will at best cause early lamp failure. The sound you are hearing could be the ballast trying to ignite a bad lamp caused by a mis-match. I hope this helps!
Nov 25, 2017 | Samsung HL-R7178W 71" HDTV
My KDS-50A2020 TV has an error code indicating a lamp driver fault (5 red blinks). I replaced both the lamp and the ballast and it still doesn't work. I need further assistance troubleshooting the...
Hello.
Ballast in Sony is one of the most reliable parts, almost never goes bad.
I assume you have TV unplugged from the wall outlet to reset error memory (not to mention that you have to do it anyway during ballast replacement).
I hope you are using good quality lamp, because cheap substitute from E-Bay can cause same problem. Lamp and ballast works as duo and on-board diagnostic system is unable to separate them unless lamp is completely blown (in that case you will have steady "Lamp" LED blinking).
You need to set TV up with back cover removed but lamp door attached (there is switch that prevent TV from working if lamp door is removed). You need to locate large 2-wire connector on ballast and make sure that it's getting about 330V DC from power supply board when you turning your TV on. If it's not there - you have power supply board problem. There should be fuse on it (not on the ballast board but power supply board - just trace those two thick wires where they coming from). That fuse could be blown by previous bad ballast shortage.
Small connector on ballast have 5 pins. Some of them ground, one of them steady 5V and another trigger (turn on signal) 5V. Make sure all voltages are there. If there is no trigger 5V - you have problem with main board.
In my experience 90% cases - it is very bad quality new lamp or something is just not connected (forgot to put plug all the way or something).
Russ.
Aug 17, 2010 | Sony KDS-50A2020 Television
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Wd-52628 bad lamp or bad ballast?
you cant - unless you have another tv to test it in. May be a ballast or the cooling fan for the lamp is not working.
Feb 02, 2010 | Televison & Video
The tv makes a loud noise - timer/lamp lights light up but no picture/sound. Changed bulb - tv worked for a short while. Now issues starting all over again. What could be causing this?
Ballast Board that connects to Lamp it could be bad or recheck to make sure its pluged in good anyway Ballast Board is what turns Lamp on Loud Noise means Color Wheel which can also shut set off Id say Color Wheel Call Encompass Parts 1-800-638-3328 they List all the Parts you need Part# for color wheel is BP96-00674A cost 129.69 They also have Service Maualfor your TV. Also Look on E-Bay under Electronics found some good deals thier Got my Lamp for 85.00 and Ballast Board for 65.00
Nov 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-R5067 blinking lights
when is the wheel is broken doo you cleaned the glass around because if it not rotate tv not turning on it is a one of the posibilitis
Mar 02, 2017 | Samsung Televison & Video
Mitsubishi WD 62327
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
My best gess is the Ballast.
Aug 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
2,297 people viewed this question
Computer Repairing
Computer Repairing
