Question about MSI Microstar KT6 Delta (MS-6590) Motherboard
Ms 6724 ver 1 password req to enter the bios to enable boot from cd req thanx peter smith
  • 2,296 Answers
Posted on Feb 17, 2011
Need BIOS password to enable boot from CD
Go to command prompt
Or
Press and hold window key and press "R" key
Type CMD and Enter
Type debug and Enter
Type o(not zero) space 70 space 2E and press Enter.
Type o(not zero) space 71 space ff and press Enter.
Type q and press Enter.
Now restart your computer
May 06, 2013 | Computers & Internet
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
How can i enable sata in bios for msi motherboard pm8m-v ms-7104 v.2
Go for bios setup >advance bios feature>Boot sequence>and select any one of them >enter>1st boot will cd and your hard disk will be 2nd >press F10 >yes/enter,
contract for further instruction.
Hope this helps.
Sep 30, 2011 | MSI PM8M-V Motherboard
How to boot from dvd using MS6590 ver 2.0 with VT8237 controller
Turn the computer off.
Turn the computer on, and look for the message:
Press <BLAH> to enter BIOS SETUP.
Press the <BLAH> key.
Change the "boot-order" to make the CD/DVD the "first" boot-device.
Save/Exit from BIOS SETUP.
Insert the media into the CD/DVD device.
Boot from the media.
Aug 02, 2011 | MSI Microstar KT6 Delta (MS-6590)...
Micro star mian board passward on bios ms-6724
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Intel MicroStar MS-6724 Socket 478 P4...
Forgot start up password
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
now for the password
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
also
http://download.cnet.com/%7Bvalue=http://www.download.com/mail-passview/3000-2092_4-10466299.html The nature of password-retrieval software makes it more likely to trigger alerts from PC security. Password-retrieval software can be used maliciously, especially if someone else has access to your computer. Take care when installing and using Mail PassView is a small password-recovery tool that reveals the passwords and other account details for the following e-mail clients: Outlook Express Microsoft Outlook 2000 (POP3 and SMTP Accounts only) Microsoft Outlook 2002/2003 (POP3, IMAP, HTTP and SMTP Accounts) IncrediMail Eudora Netscape 6.x/7.x Mozilla Thunderbird Group Mail Free Web-based email clients. What's new in this version: Version 1.73 added 'Mark Odd/Even Rows' option, under the View menu. When it
Apr 12, 2011 | Computers & Internet
My notebook from one moment to another black screen appears a lock in the corner and I asked for a password, I can do? hopefully can help me. thank you very much from chile.
or
or
hope this helps
or
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
I want to reset password of DELL Optiplex Gx-280 to enable cd rom on boot option .
remove the jumper, they have two pins only, turn on the computer, wait for 1 minute. The jumper is located close to the power plug, in the right side,
Apr 09, 2011 | Dell Optiplex GX280 (99301) Motherboard
Long POST and will not mount HDD.
first of all, you need to another 512Mb of memoires. it will run better. second, go to BIOS and search for boot order, chaneg the the boot order to Hard driver first.
May 01, 2009 | Computers & Internet
MSI Microstar KT6 Delta (MS-6590) Motherboard Logo
384 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
