Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a whirlpool S20BRBB20-A/G side by side fridge freezer, display panel makes clicking noise and flashes on and of. It seems the supply to this panel overloads. If I switch of ice maker clicking and flashing stops, but when I open the door and light comes on it would start again. I must mention that controll board has been changed before. Thanx!
  • 66 Answers
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Posted on Dec 26, 2007
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
SOURCE: Whirlpool GD5RHAXNQ00 Ice maker not making ice
We had a similar problem and there was a broken/stripped gear in the icemaker. A&E replaced it to the tune of $150 or so. I don't recall exactly but I recall my husband thinking he could replace the entire icemaker for the price we paid to repair it. The gear make the ice tray flip out the ice once frozen. Good luck, hope that helps a little.
Posted on Jul 15, 2008
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
SOURCE: Whirlpool Gs5shaxnb02 Ice maker
HI!
In my refrigrator ice is not making . My frig is about one year old side by side. All of a sudden I noticed water stop coming in the ice dispenser. Please advise me what went wrong.
Thanks
Posted on Aug 18, 2008
Temperature display flashing and continuous clicking noise
Your electronic board needs reprogramming or replacement. Very common with Whirlpool fridges.
Dec 18, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
My whirlpool american fridge s20BRBB20 A/G clicks and clatters and front panel flashing. Fan and motor changed but problem persists
if the clicking is from the ptc overload relay on the compressor unplug it off the compressor and replace it,if the clicking is coming from the main control board and the front readout is flashing/strobing the board is bad,but before you replace this board make sure there are no inopertive fans as this will ruin a new board immediately
May 13, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Touch Control Panel inoperative
I have the same problem than bryonh330.,inoperative touch panel an flashing all the time with a clicking noise.Very annoying.Replacing the panel seems to be be fairly straightforward(a couple of screws under the grill).Is changing it the solution??? thanks
Apr 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL REFRIGERATOR DISPLAY FLASHING AND NOT COLD
Before replacing the board, you should try replacing the starter relay on the compressor, presuming the clicking is coming from this area? The flashing could indicate that the fridge is out of setpoint temperature range and is an alarm to this fact. If the clicking is coming from the board area, it is a relay trying to come on. Hope this helps.
Mar 20, 2009 | Refrigerators
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side fridge freezer s20-d rbb32 a/g
Either there is a loose connection at that board or in the plug where the wiring goes into the door (should be at top or bottom door hinge). If all connections are tight then replace the board. Not sure how old this unit is but it does come with a one yr warranty from date of purchase.
Oct 06, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
397 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
