I have a smartdrive 9 excellance 7.5 washer that that wont fill and only squirts water several times and then stops, beeps and 3 or 4 random lights flash. The board was replaced 2008. Please help.
  • gabeachell Sep 05, 2010
    thank you for you fast service. I wanted you to know in the event that someone else has a similar problem that it was the balance switch. It was sticking and needed some cleaning .
    very informative but wasn't what I needed. I could have explained my situation a bit better perhaps but fast service appreciated.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
Parts that may be involved in filling problem are inlet hose and lines, inlet valve , pressure switch (this detects the water level), and finally the timer control board.
Start disconnecting power, check that the inlet hose is not kinked or blocked, and ensure that there is pressure from the lines.
next steps before eventually going for control board are testing the inlet valve and the pressure switch.
The inlet valve is tested reading Ohms at its contacts, if Ohms go to infinity then the solenoid is open and the valve is tested. The valve may also be mechanically faulty. A full test involve Volts reading at valve contacts.
The pressure switch is more difficult to test, as full testing is done reading Ohms with tub full. Try cleaning the tube attached to the sensor, blow inside the tube to remove blockage. If that does not work try replacing the sensor, the part is not expensive.
If all that does not solve the problem, then the timer board is defective. Full testing is done reading voltage at board terminal, but if you have done all testing above, you can replace the board at this point.
Testing must be done by a technician.
Here diagram.
Posted on Sep 05, 2010
  • Ginko
    Ginko Sep 05, 2010
    Hi.
    I did not mention balance switch and lid switch, both can cause no filling. Balance switch is also not uncommon on this washer. Lid switch was to exclude, as it causes no filling watsoever, balance switch instead was causing filling to stop immediately after starting, hence the squirt. Thanks for the update on the repair. That is really helpful.
    All the best.
    Ginko
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Washing Machines Experts
