Hi, I have a Toshiba washing mashine model AW-1150s. I try to do my laundry today, and the screen which normally show the time remaining only appear such as 0.6, 1.5 etc. While it reach to spin it will stop and the error code e2 will appear. Please help me to solve the problem, thanks
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
Toshiba washing machine model AW-1150S: error code E7 -4 @ spin, then stop.
Google owners manual for that model and brand and it should tell you what it needs, actually just google the brand, model, and the error code its giving you and i bet you big money that google will just tell you.
Aug 11, 2011 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
