Question about Liebherr KELB 2840 Premium biofresh Refrigerator
Liebheer Premuim Freezer makes occassional very loud bang and trips out all electrics in the house. Local Liebheer Engineer could find no electrical fault. What is causing the loud bang and what can I do to stop it cutting out the electrics?
  • 944 Answers
The loud bang is caused due to compressor.When the compressor coil is faulty one it will make loud sound.While making the sound it will take heavy voltage to start up the the compressor.While switching on the compressor and when it starts the compressor you can see the fluctuations in the all electrical equipment in your house.You have to change the coil
Note:When there is No proper voltage is being supplied to the Freezer the compressor will make sound to start and high voltage is being supplied,so it trips out all electrics in the house.You have to check weather necessary voltage is being supplied.If the electricity volt is the problem,You have to give separate phase for it from the main connection.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
My Frididaire upright freezer is making occassional squealing and knocking sounds. model FFU14F5HWN. Any ideas?
Sounds like a compressor or a condensing fan motor. If it is the fan motor most of the local motor supply houses carry them.
Nov 01, 2014 | Freezers
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
#Amana ABB1921DW, Frige, freezer on the bottom. Fridge is freezing all food, and there is a loud banging inside . Fridge is at the lowest setting. Freezer is fine. Anyone with any ideas or same...
You will need to check the=> 67003410 Damper Control If it is not working properly or blocked by ice from the freezer no mater what setting you choose it is going to get too cold or if closed too hot. Here is a link to how to test the auto damper=> HERE Not sure what the banging is caused by unless the fans are hitting their housings or ice formed around or near the fan blades, Can you tell me where the banging is coming from like freezer or below the refrigerator in the compressor area? Sea Breeze
Sep 04, 2013 | Amana Refrigerators
Maytag neptune dryer making loud banging noise mde6700ayw
First, check the vane's (paddles inside the drum) to see if one is loose. Post back the results.
Nov 06, 2012 | Maytag Neptune MDE6700A Electric Dryer
Hi. my BEKO condensor sensor dryer cuts out the electric mains flip switch when i turn it on. Have checked the fuse and lead no damage, checked socket and it works other appliances. What would cause t
The same happened to our Beko DCU8230 last week still under 1 year warranty, loud bang, burning smell and trip switch flipped. Beko Engineer who called said mains suppressor capacitor had blown.
Aug 27, 2012 | Dryers
We recently bought a new Hotpoint WMF760P washing machine and within a couple of weeks of using it noticed that it kept tripping all of the electrics out in the house, when it goes into it's final fast...
I have seen this before with a number of machines when they were a little overloaded. I've never been convinced that I understood why it happened, though I always suspected a motor overload of some kind causing the issue. This said. There is absolutely no reason for a machine to trip the mains unless it's faulty.
If you have a friendly neighbour who doesn't mind you killing the power in their house, you could always run an extension lead from a neighbour to your house and see if it kills their power too. But like I say, at the end of the day, if it trips the power and you have your electrics checked, then I would INSIST that you get a replacement from Hotpoint. Things that use water and electricity are not to be messed with!
Sep 08, 2011 | Hotpoint Aquarius WD640 Front Load...
When I pull the trigger on handle the breaker in the house trips.
if the breaker in the house does not trip with any other appliance connected to it ie another electric motor say a pool pump or electric motor from a circular saw and does not trip
then it sounds like your blaster has a electric phase to earth short circuit
it will be pulling a very large current
i suggest you take it to your local electrical repair shop to check this out
cheers pauly46
Apr 09, 2011 | Karcher K3.68MR Electric Pressure Washer
My side by side refrigerator is making a noise pretty loud
Hi, i think the noise is coming from the refrigerator compressor. What is probably happening is caused by a broken mounting spring inside the hermetically sealed compressor housing upon which the electric motor sits. If one is broke the motor will bang against the sides of the housing causing the loud noise. You need to call in a tech to verify the problem and if it is what I suggest, then he should go on with the repair.....
Jan 22, 2011 | Jenn-Air Kitchen Ranges
The electric keeps tripping in my house, why is this?
it is something that is being pluged in or a short in 1 of the plugs on that circut
Dec 15, 2008 | Dewalt DW824 5" Electric Angle Grinder
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Liebherr KELB 2840 Premium biofresh Refrigerator Logo
88 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
