Question about Breville ESP8XL Espresso Machine
Espresso Machine Stopped Working
Hello Top Appliance Experts!! :)
My Breville ESP8XL Espresso Machine (Cafe Roma) suddenly stopped heating water, and of course no longer makes coffee. The machine is about 7 months old and has barely been used once a day. It literally went from making a nice espresso to nothing, all within the space of an hour.
Calls to Breville customer service have been one-sided, as they never answer or reply to emails. (Wonder how you get a job like that??)
Help!
Carrie
  • ktr3 Oct 22, 2008
    My machine just stopped working. No hot water.
    Now what?
    Can I return it to Breville? Has anyone done this successfully?
  • solonscout Dec 16, 2008
    I have the same problem where it is just not heating.  Is the thermostat fuse something I can get at the hardware store and replace myself?
    Thanks,
    Kim
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
Posted on Sep 18, 2011
  • Andmccal Sep 25, 2011
    Had exactly the same problem and thought it was the thermoblock. Was about to buy a new machine and then read your post. 10 min later machine working fine. Must be a design flaw as the same blue cable was arcing and showed signs of scorching... Not good in a home appliance.
  • spinella812
    spinella812 Jun 09, 2012
    you helped me tremendously! Same situation on my 3 y.o. machine, probably used about the equivalent of 1-2 years.
  • 515 Answers
I think there are a thermostat fuse inside the machine, you have to open the top.
Posted on Jul 16, 2008
  • coffee432 Jun 21, 2011
    Do you recommend replacing the thermostat fuse or what?
    New Friend:
Same problem for my machine. I opened the top by removing the two screws behind and the screw on the top. There are also two screws that are accessible with a long screwdriver on both sides of the portafilter (the screws retain the top also). See drawings in link for details.
I also had the blue connector connected to the heater completly burned. I managed to fix it with pliers and I added some solder to ensure a better electrical contact. I also added some solder on the red connector (also connected to the heater) because it turn red and fumed when I turned the heater on again. These connectors have poor contact and may heat up with the high current passing to heat up the water. Just make sure that there is a solid contact and that it cannot get loose during the vibrations of the pump.
Espresso Machine Stopped Working - espresso-machine-stopped-working-syjo3oslt4oeoelmb34d3cdl-5-0.png
Posted on Oct 11, 2015
  • 3 more comments
  • Mayce
    Mayce Feb 14, 2016
    Hi, I have the same problem, but it looked like two blue wires were connecting to the red terminal. One was from the bottom of the machine and the other from the top. I'm not sure if I should be fusing them both to the red terminal? In your photo I can only see the blue wire coming from the top. I have the exact same model... any ideas would be super helpful!
  • Mayce
    Mayce Feb 14, 2016
    here is a photo of the makeshift job...It started to heat up the water fine, I just want to make sure it is safe before I solder and secure it more. You can see the wire from the bottom as well as from the top, and I am not sure if both are supposed to be connected to the red terminal. When I first opened it, it looked like maybe the bottom wire connected to the top wire, then the top wire alone was onto the red terminal? Can't be too sure. Any tips would be very appreciated! Thanks!
  • Mouton
    Mouton Feb 17, 2016
    Hello Mayce!I am glad that my post helped you fix your machine!I checked mine and there are really two blue wires attached to the red terminal. Happy espresso!
  • David Kotschessa
    David Kotschessa Jul 17, 2016
    Thanks for this. Tightening with pliers worked for a few days but then came loose again. I decided it was time to learn how to solder. I ordered a kit and gave it a go. After dripping solder everywhere but where I wanted it, I finally managed to solder the parts as shown. However, on operating the machine,the parts heated and melted the solder right back off again. Thoughts on what newbie mistake I'm making here?
  • Mouton
    Mouton Jul 17, 2016
    Hello David. I'm happy my post could help you too. It also happened to me. It happens if the connection is not good enough. If there is lot of current that pass through a very small metallic contact, it will heat up a lot. You just need to be patient and try to solder and tighten it up so you have a nice and large metallic contact. The vibration of the machine does not help too because it can lossen weak connection. In summary, if you have a good connection, it wont heat up and the solder will hold up.
    Good luck! :-)
    New Friend:
Instead of soldering the 2 connectors, I used part of the electrical connector showed in the attaches image ( pointed by an arrow). This creates a solid connection between the 2 items, and now the water heats up un less than 20 seconds.
Espresso Machine Stopped Working - espresso-machine-stopped-working-eorfyyfkldl2pwazpsvppnvh-3-0.jpg
Posted on Nov 01, 2016
    New Friend:
As Hans suggested, take off the top and check the blue wire feeding into there abloom. Mine was corroded and snapped so was only occasionally providing contact. 5 min solder job and machine now consistently heats up in about 2 minutes versus ( 20minutes to never )that I had previously experienced.
Posted on Apr 22, 2013
  • Filip Jakob's Apr 22, 2013
    Sorry that should read "feeding into the thermablock unit"
My breville cafe roma wand is not steaming it is just making air bubbles
Have you tried cleaning out the machine? My steam wand started just spraying out a steady stream of water but was not heating up. I used the cleaning solution CLR (8 parts water, 1 part CLR) and let it run through the steam wand for awhile. At first it just kept streaming out then all of a sudden it stopped. I still kept it on just to see what would happen. After about 10 seconds all of a sudden the steam wand shot out whatever had clogged it and it works perfectly again! I had only used the machine about 10 times before this happened. I had not been cleaning it well after each use back then. Now I definitely do.
Sep 13, 2010 | Breville ESP8XL Espresso Machine
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Dec 27, 2009 | Breville ESP8XL Espresso Machine
The frother on my cafe roma has stopped working. I removed the wand but where the steam comes out is stopped up. how do i fix this
The "frother" is probably blocked. Remove it and see if you can blow through it. If not, you can try cleaning it with a paper clip. If that won't work, place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile. After it cools, try using the paper clip again. You should clean the steamer attachment after each use:
2. Remove the froth enhancer and rinse under warm tap water. 3. Wipe the steam wand with a damp cloth. 4. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand.
Oct 30, 2009 | Breville ESP8XL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Water leaking out of the tank
i think you have to replace the gasket where the water tank fits, it´s very tight there, you have to take off the bottom from the machine then you will see two screw, loosen this.
Now can you put down your hand in the hole and take of the plastic above the gasket.
Hope this will help you.
/Mirran
Aug 15, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
2,411 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
