Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20 could you tell me how to change the flyback?
  • RCA Master
  • 8,617 Answers
You will need some solder wick to remove the old solder. You need to heat up the old sloder with a solder iron and while its molten touch the solder wick to the solder and the wick will absorb the old solder. You will need to keep trimming the solder wick end so it will keep soaking up the old solder. Do that to all remaining pins on the flyback. The replacement flyback will not come with the high voltage wire attached so you will need to remove the wires from the flyback. This is accomplished by twisting the wire 90 degrees while exerting upward pressure. Instalation is the reverse of removal. Let me know if you need additional assistance.
Posted on May 12, 2008
Rca d52w20 when i push power it squels then powers off.
replace the flyback. You can get the 259296 flyback replacement kit at the following link which contains the flyback and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd52w59 power button lights up for 10 sec than shuts off
the flyback is 259296 you will also most likely need cP150 you can get replacements with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20
0cc3c24.jpg CPi50 is on the right CP114 is one the left and the flyback is at the lower left hand side black transformer
Sep 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
CP 150 Capacitor and Flyback
very easy you need flyback 259296 and the capacitor is 2200uf 25V radial. You can get replacement flyback and capacitor at the following link and they provide step by step instructions on how to do the repair.
Sep 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power up
the flyback error is usally the power led will blink three times when power is pressed then go out. does your set do that when the power is pressed one time?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 flyback question
If your model number is D52W20 you need flyback number 259296 and you can get a new flyback at the following link and they will givce free online tech support to walk you through the removal and replacement procedure.
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light blinking 3 times....
If your model number is the D52W20 RCA the 259296 is the flyback that your model uses. They just dont list all the models that the 259296 uses. The 265409 is the same flyback but for GE models the mounting tabs are a little different but they are both the same elctrically but the 259296 is for the ITC222 chassis which is the D52W20. They dont have a link for flyback instructions what they do is sign you up for instant messageing when you order a flyback so they can explain the proceedure while youre doing the repair, as a flyback is simply unsolder the old and solder in the new. It takes only a few minutes to do the job.
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20
the flyback is the transformer with the RED wire that resembles a spark plug wire you can get one at the following link for under 50 dollars and comes with free tech support by way of on line instant messageing. They sell that flyback which is a part prone to failure. Its the only RCA flyback that they stock. Heres the link.
Apr 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
