Question about Samsung NV10 Digital Camera
Card error,cant take pictures - Samsung NV10 Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 05, 2010
Cant take pictures as CARD ERROR report comes up every time i turn it on
Possible that the SD card has errors or has corrupt files. It will be best to remove and insert on the card reader of your PC . Scan for virus or try to load into the memory. If there is issues the card must be changed, try with another card. If not the camera has errors in the slot or the card interface.
May 28, 2011 | FUJIFILM FinePix J28 Digital Camera
My camers says file error everytime i turn the camera on i cant uplod,take or look through the picture, please help??
Take your card out of the camera and put it in a computer, If you can see the pictures copy them then format the card.
If you can't see any pictures try to use a free recovery software like Recuva (just google it to find where to download). Once the pictures recovered, format your card.
It the camera still shows file error, the card is certainly damaged.
May 07, 2011 | Cameras
SD CARD DOES NOT SHOW PICTURES ALREADY ON IT IN FUJI Z35
Your previous camera wasn't another Z35, was it? Most cameras will not display pictures that were taken with another camera. The old pictures are most likely still on the card. You can plug the card into a card reader and transfer them to a computer.
Mar 14, 2010 | Fujitsu Cameras
Card error on Agfa digital camera
Get a card reader (they don't cost much) and download your pics to your computer. Then, put the card back in the camera, go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and optimize your card. My advice, don't leave your pictures on the card for very long...get in the habit of downloading on a regular basis and format the card regularly.
Nov 16, 2009 | Cameras
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
Picture error
I would recheck all of my settings on the camera. Go to the menu and check everything one by one. Your card may be damaged also. Do you have another card to try? Do you have your manual? If not you can to to www.olympus.com to download a new manual specifically for your camera and it may address this issue. Good luck.
Aug 14, 2008 | Olympus SP-700 Digital Camera
My camera wont take pictures card read error
I took a pictures with my camera and now some I cannot view some of the pictures it says Picture error
Dec 20, 2007 | Olympus FE-100 Digital Camera
Samsung NV10 Digital Camera Logo
176 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
