Question about Intel D845GEBV2 Motherboard
How to set a boot device to do a boot please help me i am not getting..........
  • Intel Master
  • 27,725 Answers
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
Posted on Sep 05, 2010
My computer froze,so i did a force shutdown.now its telling me reboot and select proper boot device or insert boot media in selected boot device and press key.dont understand whats going on
Hi
Please check your Bios setting its may change, press the del for the set key when computer boot (Please check your PC compact able key for setup) and select the boot sequence first boot from Hard Disk, Second Disk CD-Rom and select none on third boot, press F10 to save setting and your PC Restart and now you get your windows proper.
Good Luck
May 11, 2011 | Computers & Internet
After Planet driver installation i have message : no boot file name received for realtek fast ethernet controler, the animation and windows starts. If card is removed out everything is normal. Please...
If I understand you well, before Windows loads, you get a notification about the ethernet controler. If this is the case, then you'll need to go to BIOS and change the boot options, so that your hard drive is set as first boot device, then DVD as second boot device, then USB drive as fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot device, and in corporate networks PCs bet such a setup so that there's one large server feeding data to the local cubicle PCs to such extent that these cubicle units are just "dumb terminals". In your situation, your PC thinks it should too get boot infro from the LAN, but as your PC is not a part of a corporate network it waits in vain, and after a while it moves on to the second/third boot device, and then finds that it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option.
If this was informative please give it a Thumb Up. Thank you.
Jan 20, 2011 | Planet Technology ENW-9605 (enw9605)...
I have an Acer Aspire1 Netbook and below is the problem. Went to BIOS set defaults but still get the same thing: For Atheros PCIE Ethernet Controller... check cable connection PXE-MOF:exiting intel PXE...
A computer tries to "boot" from many devices:
* 3.5-inch floppy-disk (if available)
* USB memory-stick (if connected)
* internal CD/DVD device
* external CD/DVD device
* internal disk-drive
* over your network-cable, by talking to a "network boot server".
When it tries to boot over the network-cable, and *NO* "boot-server" responds,
you get the "check cable connection" and "exiting from P(re)(e)X(ecution)E(nvironment)" mode.
If it cannot boot from your 'C:' drive, and cannot boot from the network boot-server,
your computer responds "no bootable device" and "insert boot disk" (into CD or floppy-disk),
and "press any key" (to try again to boot).
What this USUALLY means is that your 'C:' disk-drive has stopped working,
meaning that Windows cannot be "booted" from it.
Seek help from a qualified technician to trouble-shoot your disk-drive, and/or to replace it, and/or to reinstall Windows, and/or to "repair" your existing Windows installation.
Dec 28, 2010 | Computers & Internet
Working on a Dell 530 Desktop, installed a new WD 500gb Sata Hd and after setting up Boot in cmos cant get by following Boot to CD Boot Device not installed enter ready to continue. Need Help OS CD in in...
Go back into the Dell CMOS and try reseting all settings back to default. Restart and when it starts to boot, start tapping F12 to get to the boot menu. Try booting to the CD drive now.
***Please rate if this helps you or ask more detailed questions for more help. Thanks
Dec 15, 2010 | Dell Computers & Internet
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
Sep 19, 2010 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
I just installed a new hard drive into my gateway desk top and put recovery cd in and its says missing operating system
You will need to go into the BIOS screen and set the first boot device to CDrom. You can get to BIOS when the machine first boots, as soon as you see writing on a black screen press the bottom to get to setup. When you get to the setup screen look for an option to set boot devices or "boot priority". The first boot device needs to be CDrom and the second device can be Hard Drive. Now save the settings. This time on boot the computer will boot to the CDrom restore disk and you can follow its guides to restore your system.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | Computers & Internet
Bios settings?
these settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and lan.....so try to set your boot device priority with hard drive as first device....this will solve your boot up problem....do reply back
Oct 02, 2009 | Computers & Internet
Initial set up problem. Acer net book
this small laptop does not comes with cd rom,So you can arrange a USB Optical drive.In bios setup please check for boot sequence is to be set for usb boot device.Now insert the bootable cd or Operating system cd with boot files & it ill works
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
My computer restarts and won't turn back on.
Have you checked to make sure you don't have a cd/dvd in the rom drives? Sounds like it might be trying to boot up to something left in a rom drive. If not may be set in the bios to not boot from the hard drive (the bootable device). In this case you can change the settings to be sure this isn't the problem. Could also be a corrupt operating system or hard drive failure. But before I get in to deep, there is no date on your post. If you are still having problems and would like some help please send a note and I will be glad to help you.
Jan 21, 2009 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Intel D845GEBV2 Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
