Question about LSN 7Online - New York newsweather & sports
What is the difference between this and another station?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
Each one has differant shows
Posted on Sep 05, 2010
Testimonial: "thanks man"
Why can I only get my one local am station when the fm works alright
AM and FM transmit differently, so \it's not surprising that there's a difference in the number of stations you pick up. Also, AM radio is a dying medium, so there may not be as many staions in your area as there are FM.
May 06, 2015 | Sony WX-GT90BT - radio / CD / MP3 player /...
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I have registered a (different make) GAP compatible phone with my base station and can get a dial tone but no other functions ie address book. Any suggestions?
Yes, buy the correct one and follow the instructions in the manual. We are unable to give advice when you won't say the make and model of your base station or the (Different make) handset. I mean, does your new handset even have an address book function? Does your base station have an address book function?
Oct 13, 2013 | Lands Phones
What is the difference between a base station and a sub-station in an intercom system?
a base station can initiate calls with any other station in the system, while a sub-station can only communicate with the base station
Jan 29, 2013 | Radio Communications
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Having programmed by car stereo with the FM stations I required (newly bought car, 1 year old), I find that the programmed button number 3, which is programmed to station 97.3 jumps to 102.7 without...
you may have auto seek (rds) which when the signal is weak it will search for the same station or one it thinks is the same station with a stronger signal, you should be able to turn this function off, also the button normally acts as "2" presets so the switch may be defective
Jan 03, 2010 | Car Audio & Video
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
2003 Lexus ES300 How does one save Radio Statio presets? Going to the station and holding the button to save does not work.
Holding the button is supposed to work. This from owner's manual: PRESETTING A STATION:
  1. Tune in the desired station.
  2. Push one of the station selector buttons (1-6) and hold it until a beep is heard. This sets the station to the button and the button number (1-6) appears on the display.
Each button can store one AM station and two FM stations. To change the preset station to a different one, follow the same procedure. The preset station memory is cancelled when the power source is interrupted by battery disconnection or a blown fuse.
Jan 08, 2009 | 2003 Lexus ES 300
Car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Oct 20, 2008 | Becker Car Audio & Video
LSN 7Online - New York newsweather & sports Logo
114 people viewed this question
Top LSN Apps Experts
Bill Boyd
ray gallant
Are you a LSN App Expert? Answer questions, earn points and help others
