Question about Achiever CCS5000 Shredder
SQUELLING PROBLEM HOW TO FIX A SQUEELING SOUND WHEN FEEDING PAPER IN MANUAL MODE AND AUTO MODE? THANKS, LINDA
Try Oiling the cutting head, if it still does it you may need a new belt
Posted on May 13, 2008
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
SADF Mode problem
Try turning off the machine, pushing and holding the utility key and turning it on, don't take your finger off the key. You should see a blank screen with one touch button on it saying Trouble Reset. Press it, if the machine doesn't reset itself turn it off and one again.
Jun 14, 2007 | Konica Minolta DiALTA CF910 Copier
Achiever CCS5000 Shredder Logo
101 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
