Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Write protected when i format my usb flash drive it say cannot formatted because its write protected
    President:
  • 1,257 Answers
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb ..if its not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 11, 2008
  • 35 Answers
Hi herald77,try locate a switch which enables write protect in ur flash drive.have a nice time.
raj..
Posted on May 12, 2008
4 Suggested Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
repair_v2.9.1.1.zip
good program. kdt100-4gb now is ok
Posted on Feb 04, 2009
  • 7 Answers
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
  • 1170 Answers
SOURCE: how to format write protected
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (F8) key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Note:
Before removing USB from your computer, Always remove it safely by going into to my computer then right click on USB and click eject.
Thanks
Posted on May 21, 2011
How to fix a write protect usb flash drive
Both these links have some good advice
http://www.tomshardware.com/forum/265507-32-format-write-protected-drive
http://www.techrepublic.com/forum/questions/101-207273/usb-flash-drive-is-write-protected-how-do-i-remove-it
Apr 16, 2013 | Electronics - Others
Usb flash drive unable to format
Your problem of flash driving not formatting can be because the protect switch of some flash drives. Many USB drives have a tiny write protect switch which does not allow it to be formatted so it not be placed in the right position ,try to apply this method will surly help you to maintain your usb drive last long without any issue.otherwise go for usb drive without this type of write protected switch.
Nov 23, 2010 | Transcend Computers & Internet
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
USB flash drive write protection
Most USB drives don't have a Write Protection switch, but if yours does, then move the slider.
If it doesn't have a switch, the only way to use the drive is to format the drive. First, note the drive letter, such as E, F G for your drive. *** BE CAREFUL *** This will remove all files. Go to Windows Explorer, note the drive letter , Right-click and select Format. Again, BE CAREFUL not to format any other drive, just your removable USB drive.
Hope this helps.
Aug 10, 2009 | Electronics - Others
Usb not formating due to write protect
Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
 Best of luck.....
Jul 24, 2009 | Electronics - Others
My usb drive is write protected i cant format it pls help....
Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
Jun 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Write protected
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
May 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected flash drive
my usb flash drive shows that it is write protected when i tried to format it.
how i can solve this problem?
Oct 27, 2008 | Transcend (589307) Media
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
301 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
