Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
In the middle of the wash stops and says LE - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
Error code LE
I am sorry the code is hp
Mar 08, 2014 | Maytag MAH8700A Front Load Washer
IE error in the middle of washing it seems to stop and the motor sounds labored.
LE error code means the motor is resritcted or locked up. you can try to clean out the sump area but will most likely need to replace the Wash Motor
Sep 12, 2011 | LG LDF6810ST Stainless Steel Built-in...
Cycle stops and the code FE appears and to refer to manual but I don't have one, can you help
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Must be some sediment in the water level pressure hose. Blow out the sediment, reconnect the hos, pump out the water and retry. This is an lg washer. You may only need to set or reset the water level frequency. I have service manuals and notes HERE
Apr 06, 2011 | Washing Machines
Stops and shows flashinng OE when I open door clothes are sitting in water
IE: Water level (246) was not reahed in 8 minutes
middle of L. Upside down F) Thermister out
Service manual and more HERE
Jan 05, 2011 | Washing Machines
My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I...
this means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Sep 11, 2010 | Washing Machines
I am getting an message LE. I am trying to wash
LE unfortunately is the fault code for a faulty Hall sensor or faulty Motor.The Hall sensor is attached to the motor. If you have or can borrow an electrical test meter the I can guide you throe the testing.80% of the time it is the Hall sensor.Hope this helps please reply for further help.
Jun 06, 2010 | LG WM-2277HW Front Load Washer
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
