Question about PNY Optima Pro 2GB Secure Digital Memory Card
Hello. I have a Samsung VM-MX25E H.264 video camera & i was video taping. When my PNY Optima sdhc memory card was full i took it out while the camera was still on. When i put it back in the camera wouldnt read it anymore. I went to Best Buy to check if the card worked with other cameras & it did but it does not work with mine. I would like to know the problem and the solution. Thank you!
5 Suggested Answers
roospeed25
  • 17 Answers
SOURCE: hEllo... well my
Put the card back into the device then hook the device up to your computer. if that doesnot work then buy a cheap updated USB card reader
Posted on Jun 07, 2009
  • 193 Answers
SOURCE: I have this my pny optima sdhc 4gb and it freezes...
becoz then the autoplay of the drive will be activated and it will freez your computer......recomandation is to format the drive in computer not in the cam, or you can open the SD drive frome 3rd party software (total commander), and delete the hidden autorun files.
Posted on May 07, 2010
  • 245 Answers
SOURCE: my pny optima sd card
Format the card. That will remove everything on it.
Posted on Dec 19, 2010
Testimonial: "Thanks. I wondered if that was what I needed to do. Formatting now. You're a true genius!"
t00nz
  • 4738 Answers
SOURCE: What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Posted on Nov 26, 2011
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
I have this my pny optima sdhc 4gb and it freezes my pc when I want to get the pictures off or the videos. Works fine if I use my usb cord to the camera, but I want to know why it wont work just from the...
May 07, 2010 | PNY 4GB Secure Digital High Capacity...
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
Will the kodak easyshare z730 accept the pny optima sd hc 4 gb memory card?
No, because the camera is too old to be compatiable with teh SDHC its only compatiable with SD not SDHC.
Jan 17, 2009 | Kodak EasyShare Z730 Digital Camera
Exilim camera, PNY optima SDHC memory card error
Hi
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 10, 2008 | Casio Exilim EX-S2 Digital Camera
PNY Optima Pro 2GB Secure Digital Memory Card Logo
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
