Question about Acer Aspire 3000 Notebook
I was given a acer aspire 3000 last year. Ever since ive had it, the computer won't Turn on unless the battery is plugged into the wall. Today I've had problems w/ the keyboard. When I'm about to log in to the computer it let's me type in the first 4 letters of my password then freezes... Please HELP!!!
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 20, 2010
I have an acer aspire 3000 I logged off last night and today went to turn it on it powers up but it won't display anything just a black screen
I think your OS might have gone..... So try installing an OS CD in it and see if it displays something or not. If not then your display is gone. You have to repair it in a repairing shop.
Jun 09, 2013 | Computers & Internet
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
My acer Aspire 5741 won't charge beyond 37%
Let your computer run out of battery(until it shuts down) then plug it but don't turn it on... let it charge for about 2 hours. Post here if it worked.
Aug 29, 2011 | Computers & Internet
Acer aspire one won't turn on
Try another Wall Power Supply. To test. Take Out battery, Plug In wall supply to Wall & PC, without battery does it work OK? IF YES, replace battery still OK? Laptop Should work on Wall ONLY, if not, replace wall unit.
Apr 28, 2010 | Acer Aspire One PC Notebook
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dec 27, 2009 | Acer Aspire One PC Notebook
My Acer Aspire 3000, Keybourd Stopped Working
i had the same problem. the battery does something during startup and the only way i found to fix it was to turn it on without a battery while its plugged into the adapter, or leave it in standby instead of shutting down... i dont know if theres a better way, but thats what i do.
Apr 11, 2009 | Acer Aspire 3000 Notebook
Acer aspire 3050
im fixing a simular model.. ive seen this sevral times in the last week.. to ONLY way i could get past this was to take the battery out the lappy for a few hours then try turning on again.. it worked for me
Apr 21, 2008 | Acer Aspire 3000 Notebook
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3000 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
