Question about Whirlpool MH7135XE Microwave Oven
Microwave We have a home with a broken Whirlpool Microwave. We have removed the screws and the release bracket seems to be broken. We cannot seem to get the old one out.
    Genius:
  • 1,554 Answers
As it is over the range it may be goop from cooking that has it stuck in place, its like hard glue.
some kind of spray to eat grease may be what you need.
Posted on May 12, 2008
Open door if latch is broken
And you can't just pull the door open? I know it's easier to push the open door button but both ways should work unless the safety switch bracket moved from it's intended position. I hesitate to offer this solution, but who wants decayed food smelling up the home? Let's assume it's a counter top oven, remove all cover screws and the cover. STAY AWAY FROM ALL WIRING and I should have said first unplug the power from the appliance. Locate the door latch area and lift up on the plastic/metal bar that has a spring attached to it and the door should be released. Pushing the door release button should lead you to the latch. Once you see how it works you may find the reason the latch is malfunctioning. If it's a over the range type you will have to remove a grill at the top of the oven to access the mounting screws that release the oven from the bracket but the latch reference above will apply to this type as well.
Dec 06, 2014 | Microwave Ovens
How to remove whirlpool microwave
Usually, there are 2 or 3 screws on the top of the microwave that hold it up to the bottom of your cabinet. Have someone hold the microwave while you remove those screws. Then allow the microwave tip down about 20?, then you can lift it off the bracket on the back-bottom of the microwave, and remove it. NOTE: On some older microwave ovens, there is a lever or latch behind the grill vent that you need to pull to allow it to tip down. And on a few (very few) microwave ovens, there are 2 support arms that the microwave will slide out on, instead of tipping down.
Oct 11, 2014 | Whirlpool Microwave Ovens
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
I have a whirlpool microwave model GH7155XKT. The door cover is cracked badly and I ordered and received the replacement part. I can not figure out how to replace the Choke or Cover
Hi deflcsw,
I see you need a manual on how to replace you Microwave Door.
I checked the Manual does not have info regarding how to replace the Door just the Bulb and the Filters in it see here .
To be able to get information on how to replace the Microwave door you will need to contact Whirlpool 1-800-253-1301, you may need the Model and serial number so they can provide you info about the door replacement over the Phone if the door cannot be replaced by you then they can reffer you to a local center near your address for the replacement to take place or possibly get soemone out to replace it for you.
I hope this helps.
Have a nice day, Thank you for choosing Fixya,
mvincentc
Jul 18, 2011 | Microwave Ovens
How do i ger it to release from the wall bracket
Tilt the front down a little and lift the back to release it. The screws in the cabinet above must be removed first. When these are removed the front will drop instantly, be ready to support the weight.
Jan 23, 2010 | Sharp R-1480 Microwave Oven
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Jan 09, 2010 | Sharp R-1480 Microwave Oven
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
132 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
