Question about Panasonic Cameras
Hoizontal and vertical lines on screen---color distorted
  • 2 more comments
  • tpuccio Sep 05, 2010
    Pnasonic Lumix DMC ZS3. The vertical and horizontal lines are on the camera screen so that I cannot frame a picture properly. It looks like the lines on a tv which is not tuned
    Have you ever encountered this problem before? Should I ask another expert?
    Panasonic Lumix DHC ZS3----horizontal and vertical lines have appeared on the camera's monitor. It looks like a TV that is not tuned or hascinterference. The camera takes pictures and is less than a year old.
    Since the camera is taking good pictues can I assume there something wrong with the LCD screen?
  • 10,319 Answers
This is common to see when the capacitor in the circuitry get weak. If you did not try fresh batteries as of yet, do so. It may solve your problem. If not repairs are needed to the board installing a new capacitor.. Sometimes the cost to repair outweighs the cost of a new camera
Posted on Sep 05, 2010
  • Panasonic Master
  • 19,396 Answers
Hi.
The distorted and blurred picture and often in false colors is probably caused by a defective CCD sensor. The CCD sensor is the light sensitive chip that captures the picture. This is located inside the camera body, right behind the lens.
CCD sensor is a common failure. Here an article: Widespread CCD problems in consumer imaging product. Panasonic released a bulletin on the problem and was covering repair on models from several years. Here the forum, Panasonic removed the notice from Web. Conatact them to find out if you are entitled to repair.
Note: If the lines are well defined color bands that are not blurred and do not move, then problem may be connector to LCD, LCD display or board. CCD sensor is a more common failure.
  • Ginko
    Ginko Sep 05, 2010
    Re:"DHC ZS3----horizontal and vertical lines have appeared on the camera's
    camera takes pictures and is less than a year old."
    If the camera takes pictures, remove the memory card and read pictures using a computer. If pictures are normal on computer display, then the problem is LCD display and connector or main digital board. If pictures are distorted or with lines, then problem is the CCD.
    In both situations the camera must be disassembled and fixed. The job is better done by a technician.
    To get a quote on repair, contact Panasonic or get a quote from a third party here: Repair.
  • 4,472 Answers
Can you give me the model of the camera? Also how long have you owned the camera? After you take the picture and download it to the computer does the picture look ok? Once I have more information I can assist you further.
Thank you,
Lee
  • Lee A.
    Lee A. Sep 05, 2010
    Being that the camera is less then a year old you will want to have it repaired under warranty. Follow this link to start the repair process:
    http://www2.panasonic.com/webapp/wcs/sto...
    If it's taking good pictures sounds like its either internal connection or lcd problem and will be covered under warranty.
    Thank you,
    Lee
  • Lee A.
    Lee A. Sep 13, 2010
    I would like to understand why you requested a refund and did not rate me accordingly, when I gave you the best possible solution for a problem with your camera which is less then a year old...
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Where can I find a guide for my enzer TV ?
There are many types of distortion. Each with its own cause. Please describe the type of distortion. Are there vertical lines? Are the images wavy? Are they off-color? Are they blurry? A better description will yeild a better response.
Dec 16, 2014 | Televison & Video
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
I have a Sony KDLW3000, the picture has colored vertical lines on the whole screen,
The Tcon board is usually at fault with that symptom. You can get a replacement Tcon from www.tvrepairworld.com
Apr 01, 2012 | Sony KDL Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Lp70+ display shows a solid black vertical line
the light tunnel is either collapsing and blocking the light going through it (and needs replacement) or the vertical/hoizontal adjustment of the tunnel. if you take the lamp out and move the colorwheel (with a pencil eraser) to the clear section, you should be able to see a square through it. if part of the square is blocking the middle, the tunnel needs replacing.
by the way, on some projectors the light tunnel is called an integrator rod.
Jun 17, 2008 | InFocus LP70+ Multimedia Projector
Cameras Logo
172 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
