Amplifier problem hello everyone . i have a dvd player (LG) and it has six outputs(5.1 system). i connected the output (only the front left and right)of this this dvd player and gave as an input to my TV. The output of Tv(audio) i gave to an amplifier. My amplifier is an old one and has AUX in Left and Right as input.Now my problem is yesterday i tried to watch a movie. The video was good but the audio was not coming specially the dialogues but could hear the background music.after this i put some other dvd and everything was fine with that dvd , audio and video both.and when i removed the amplifier and connected the output of my dvd player to speakers i could hear the audio(in the first dvd).i am not able to find a solution to this problem and kindly require ur assistance.
  • 28 Answers
Here's the basic problem. The DVD player can get a 5.1 audio source from the DVD. That signal is then converted from Digital to Analog and split into 6 channels of information. Each channel has an audio out on the back of your player. You are only using the Front L and Front R outputs. Based on how I read your description, they seem to be sent from your DVD to your TV, and then from your TV to your receiver. The problem is that you are only listening to two of the six channel, so you are losing a lot of information. How this sounds to you depends, in part, on how the sound is mixed on the DVD (5.1 versus just stereo, for example).
Because you don't have 5.1 system to take all six outputs (analog "DVD Audio" connections), you shouldn't be using those outputs. You could use the digital out (optical or coax SP/DIF) to send all channels to a receiver that could do the splitting (D/A), but it sounds like you don't have the equipment for that.
You didn't provide the model for the LG DVD, but there should be connections for analog stereo. They would be labeled as Audio Out L / R, or something similar. The connections are stereo, but your player would use all 5.1 channels to play through those stereo channels. You could connect those directly to your receiver, or you can continue trying to have the TV as a step in between (not suggested unless you just like to watch DVDs without turning on the receiver).
Posted on May 12, 2008
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Connecting four speakers(, left right front, and left right rear)t and a 50 watt subwoofer to a pioneer avh-p4000dvd without using an amp.
This has four outputs with about 22 watts RMS and four pre- amp outputs. So if you need to get the 5.1 effect an amplifier is needed to be connected so as to get the center ampflier and the subwoofer activated from the preamp outputs.
The amplifer on the DVD can be used for surround effect - rear speakers - as the front can be powered by the amplifier.
please check this interesting review
Oct 01, 2011 | Pioneer AVH-P4000DVD Car DVD Player
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Jan 27, 2011 | Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Jan 13, 2011 | Spectroniq PD-3000HD
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
Wiring Connections
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
I bought a paramax p-510 I want to setup connect it to my tv, what cable do I need
i have no idea to connect it either. Specially since the AV has only 2 jacks instead of three. I connected the two jack with DVD, and the front 2 speakers work and the sub too, however i have no idea how to make the surround and center speakers work. I have tried various variations, but i think the thing is a fake made for only 20 bucks speakers without much juice.
I might be wrong but this is the first av with only two jacks instead of three, even the cable they provide has three jacks
Sep 22, 2009 | Audio Players & Recorders
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Connecting amplifier
use pre amp with 10 inputs and connect its output to aux in----in mixer.
May 13, 2008 | Audio Players & Recorders
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
98 people viewed this question
