Question about IBM ThinkPad T43 Notebook
Double display with my IBM think pad T43
When I try to have a double display (with DIFFERENT pictures on laptop screen and external monito I fail to install this.
In the menu
Desktop (right mouseclick) properties / Display Properties
I cannot select "use my win desktop in the external monitor"
Can anybody help me how I can run two applications in parallel one on my laptop monitor and one on the adjacent external monitor?
Thanks
Tom
  • optaqua May 12, 2008
    Hi
    I may not have explained it correctly:
    Dual monitor with the SAME PICTURE is no problem!
    How to run with two monitors
    TWO different applications?
    Best regards
    Tom
    Sorry this is NOT the point.
    > Dual monitor WORKS
    > How to run different applications on each monitor is my question.
    Thanks for your help
    Champion:
  • 230 Answers
Have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
Posted on May 12, 2008
Can't see my onscreen display after turning on F7 IBM T43 ThinkPad
set it to clone. it should give you identical displays. then try setting it to extended display. But make sure that your laptop display is primary display. That is why your external screen is displaying because it set on primary.
Jul 21, 2012 | IBM ThinkPad T43 Notebook
I need ibm think pad t43 sound drivers free downlod
Hi chennupatism,
You can download the Audio Driver for your Computer Model ThinkPad T43 from the below link.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ya210ww.exe
Please copy and paste the link in the Address bar of a new Internet Explorer window and press the Enter Key to download the Driver. Then, please save the file on the Desktop. After that, please double click on the download file to begin the installation. After installing the Driver, please restart the Computer for the settings to take the effect.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 09, 2010 | IBM ThinkPad T43 Notebook
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
IBM T43 laptop display
This is an example of an inverter going out slowly. Usually, they tend to just go out and you diagnosed correctly when you seen the faintness on the screen and tested with another monitor.
The Dell inverter will not fit, more than likely. They are all different sizes, lengths, etc.
I would recommend just replacing the screen of the Toshiba. You can get one for less that $50.00 on eBay and it will save you alot of hassle trying to swap out the inverter (my opinion).
Oct 04, 2009 | IBM ThinkPad T43 Notebook
I have a ibm think pad laptop. the text has gone red
You have a TFT failure - to confirm if it is not m/board related plug and external monitor to the external vga port and boot the unit. If the display to the external is ok then your TFT requires replacement.
Mar 08, 2009 | IBM ThinkPad T23 Notebook
Think pad fails to "start"
Do you have any Operating System on it at all , if you have then lets know what OS it is and the penyium of your system
ok
Oct 02, 2008 | IBM ThinkPad T43 Notebook
Ibm think pad t43 /1872/bb6 i want see where is security chip laptop mainboard\
Are you referring to the Atmel EEPROM 24RF08 chip?
If so, in the T40 Thinkpad it is under the touchpad, I suspect on the T43 in may also in the same location.
Jun 14, 2008 | IBM ThinkPad T43 Notebook
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
475 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
