Computer wont start - Computers & Internet
  • Shiva Kumar Sep 05, 2010
    select the proper booting device
    Novelist:
  • 142 Answers
Several different hardware failures can cause this type of issue. The first step that should be taken is to verify that there are no lose or disconnected wires coming from or going to the computer. If when starting the PC your getting no power than there is an issue with the power supply. If you are getting power to the PC than you should listen for the beep code on start up. 1 beep after starting the computer indicates that the power on self test (Also known as the POST) has completed with out issue. When getting any other type of beep code you should research the meaning of the code. Beep codes change from company to company. The best way to identify the meaning of a beep code is to type the manufacture, model and number of beeps into Google. Another possible issue is that your hard drive is corrupt. If this is the case than your computer will pass the power on self test(POST) but will have a message like MBR not found or one of many other errors. If you are getting an error than it is also a good idea to research the error to determine the proper fix. If the PC seems to boot correctly but there is no image on the screen than the issue may be a result of a bad video card. In that case the video card will need to be replaced.
I hope that information above has helped is some way.
Posted on Sep 05, 2010
86 dodge daytona wont start
The main logic module / computer is located in the passenger side kick panel under the dash. If I remember correctly that is the computer that controls the engine ignition. This could be your culprit.
Mar 24, 2014 | Dodge Daytona Cars & Trucks
It wont start
TOTALLY UNISTALL Norton ...rrestart the computer and NEWLY install Norton. It may also not want to start in a case where it has expired and you will have to obtain a new version.
Aug 03, 2009 | Symantec Norton Internet Security 2009
Insalled new computer,cranks but wont start
Does it start and die after 1-2 seconds or just cranks and never fires? Did it run before you installed the computer or are you trying to cure a no start problem?
Jul 12, 2009 | 1999 Chevrolet S-10 Pickup
Car wont start
The computer controls the injectors, obviously the injectors are not firing. Check that the computer is powered up; if it is, then the computer is bad
Jun 16, 2009 | 1988 Mazda 929
1998 Jeep Cherokee Larado starts sometimes and wont start others
check for dirty / bent pins on connector. check wires at harness side of pins for any corrosion. Problem is likely not the computer, based upon what you've said.
Apr 13, 2009 | 1998 Jeep Cherokee
Wont start 1996 tahoe 1500
SOUNDS LIKE YOU HAVE CONECTOR PROBLEM .CHECK ALL CONECTIONS AT COMPUTER. SPECIALLY POWER AND GROUND . CHECK FOR BURNT PINS AT COMPUTER . IF ALL GOOD YOU SHOLD REPLACE ECM.
Feb 01, 2009 | 1996 Chevrolet Tahoe
D.d wont start
other dise is worng so the your game not start
Jan 18, 2009 | Video Game Consoles & Games
Car wont start
Sound like the computer to me, if it started acting up before you changed the battery. I am not certain if your model is affected by "no power". Disconnecting the battery with no other power source can affect the RAM of the computer, Random Access Memory. The memory can be erased and the computer would have to be reprogrammed at the dealer. the only thing I can think of, sorry I cant think of something simpler or something you can fix yourself.
Jan 09, 2009 | 1999 Dodge Durango
MP4 wont start.
your m4 was corrupt.
try to connect it to the computer.
if your computer will detect your mp4. open my computer look for removable drive. right click on it then reformat.
Jan 30, 2008 | LG KU990 Viewty
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
