Question about Porter Cable Porter-Cable Variable Speed Random-Orbit Sander , Model #7336
I HAVE A CHAMPION POWER SANDER COS180, BOUGHT AT FOCUS DO IT ALL. I NEED NEW SANDING SHEETS AND HAVE DRAWN A BLANK ON LINE.
I have the same sander and found Black and Decker 93mm x 190mm sheets fit well
Posted on Feb 05, 2014
2 Suggested Answers
  • 384 Answers
SOURCE: I have a Porter Cable finishing sander ( the kind
Try a less course paper (ie # 80, or #100)
Posted on Sep 11, 2009
How to change sanding pad
Here is a link to the manual to your Royobi p400. You can download it. Tried to copy & paste the illustrations but they did not show up. Go to page 14 of the manual. Looks pretty easy, just peel down from top. Good luck. & happy Sanding.
CHANGING SANDING SHEETS AND PADS
HOOK-AND-LOOP
See Figure 8.
PAD
The sander is packed with sanding sheets and scrubbing
pads designed for a variety of uses. To change sheets and
SANDING
pads, simply pull the used sheet off the base and attach the
SHEET
desired sheet by pressing the sheet or pad onto the base
of the sander.
ROTATING THE SANDING SHEETS
See Figure 9.
The majority of wear in a precision sanding application occurs
at the tip of the sanding sheet. The unique Tri-Flex design of
the sanding sheets allows you to detach and rotate the top
two thirds of each and extend the life of the sheet.
To rotate the top of the sheet, simply remove the top two
thirds along the perforation. Rotate the sheet so that a clean
corner is located at the tip of the base. Press the sheet firmly
onto the pad.
NOTE: Scrubbing and polishing pads are not perforated
and cannot be rotated.
Apr 24, 2014 | Ryobi P400 18 Volt Corner Cat S
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
Nov 17, 2007 | Black & Decker Compact Power Screwdriver
Porter Cable Porter-Cable Variable Speed Random-Orbit Sander , Model #7336 Logo
201 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
