We have LG WP 8003 Semi Automatic Washing Machine. Its about 9 years old. This is first time we are facing problem with our machine. Dryer is making huge noise and the clothes are not getting dried. Please advise.
5 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: water gets drain cannot remain
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Posted on Sep 14, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine MOdel 22622100
If the sound is a grinding noise, this is usually a symptom of a gear case (transmission) going bad. However, it could also indicate a motor coupling that's starting to fail. If you look under the washer check for any drips or puddles of oil. If you find any, the transmission has begun leaking and needs to be replaced. If you find a black powdery looking substance, this is an indication of a motor coupling that is failing. I hope this may help you. Let me know what you find.
Posted on Jul 10, 2007
  • 343 Answers
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Posted on Apr 18, 2010
  • 6277 Answers
SOURCE: My LG washing machine smells like rotten eggs when
Washer first!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
The other possibilty for the source of the smells is the u-bend into which the washer drain goes. Either its own 'u-tube' or maybe it shares a sink's?
Dryer now-
Does that have a clear filter? I don't know your particular model but if it is like ours it may have a double heating element, one for 'low' and both for 'high'. If so it could be that the 'high' element has failed and everything is being dried on 'low'.
Hope this assists you with both and good luck!
John C
Posted on Feb 21, 2011
LG Semi Automatic WP 9220 washing machine water is not draining out what to do
Enter your model number into the self help section of repairclinic.com, you will receive specific trouble shooting info for you appliance.
May 11, 2015 | LG Washing Machines
LG washing machine model WP 8003 draing slowly during washing,how to rectify.
The drive belt could be slipping or you have a partial blockage in the pump intake/discharge/hoses. Remove from power, remove front or back depending on model. Look at the belt while its draining for any slippage. If that's ok, remove power and inspect/flush out hoses, inspect pump impeller and intakes for clogging, broken or cracked blades etc, replace as needed. Don't overlook the possibility the system its draining into could also be clogged, P trap, etc.
Nov 16, 2014 | Washing Machines
Dryer not working
Please mention the model of the machine. If this is a semi type then the motor or the timer switch can be faulty or if this is an automatic type it can be a fault on the program timer unit.
Jan 15, 2013 | Haier Washing Machines
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
Sep 14, 2010 | Washing Machines
Lg front loader
check the pump to make sure its clear ,,,,, the front of the pump if i remember right turns to open
Nov 25, 2008 | LG WM1814CW Front Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
182 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
