Question about Microsoft Windows Vista Home Premium Edition for PC
I naalis the wire end then when i put again ther is no sound
  • 3 Answers
Need to find your suond driver for your band of computer if you have a dell go to there site and look up drivers and your modle do the same if its a differnt brand
Posted on Sep 05, 2010
Wwhy do i keep blowing my meter fuse on my 93 prelude
ther is a dedad short somewhere in the line you need to follow the wire from one end to the other and make sure its not pinched or grounded anywhere
May 25, 2012 | 1993 Honda Prelude
When I took out the battery and installed a new one, I notices there was an extra cable with a negative ring and positive ring that joined at the end and this inserted into this cable that was stored under...
hi sounds like you have a aftermarket loom fited for use with a low voltage or trickle charge, chargers
normaly fitted to machines where battery acces is difficult,the 2 wires you mentioned 1pos and1 neg, will follow the same route to a plug connector to make charging the battery less challenging by simply pluging in the mateing end on the charger. follow the 2 wires to confirm this, if this is the case you can remove the wire from the machine if you dont have the charger to use with it. hope this helps with your querey
Nov 21, 2010 | 2006 Aprilia Scarabeo 500
No speaker sound from computer
you need to download the audio driver in the webpage of you computer manufactory.. just go ther put you computer moel and choose the audio driver and install and enjoy the audio again.. pls click if my solution was helpful
Dec 27, 2009 | Dell Computers & Internet
Clicking noise in the rear end of my 2005 Rocket 3
It sounds like a bearing but you need to investigate a little further. Put the bike up on its center stand, rear wheel off ground. Then spin the wheel by hand and find that sound. IF you hear the sound really try to pinpoint its location. Then of course you need to get the repair book/ maintance book and go through the trouble shooting list. Good luck
May 25, 2009 | 2005 Triumph Rocket III
Can i take apart the drum somthing keeps tearing my clothes
The best access to inside the tub is through the lid/door. Going in through the back will not give you any better access.
If the wire is tearing yur clothes, maybe you can see the end of it poking through a hole. If you can, put a pair of vise grips on the end of the wire and try pulling it back through the hole.
Apr 29, 2009 | Washing Machines
No sound on my pc
If they were working before hand, it could be something as simple as the plugs are not connected properly. The ends of the plugs are normally colored, as such the ports on the back of the PC are colored, make sure that they are connected properly. Furhtermore make sure that the volume hasn't been accidentally turned down. Goto START/CONTROL PANEL/SOUNDS & AUDIO DEVICES, and make sure that the volume slider is turned all the way to the right. Then click on the ADVANCED tab and make sure that the sliders are all up and make sure that the mute isn't checked. Good luck, hope this helps.
Mar 22, 2009 | Dell Dimension 3000 PC Desktop
Wiring? emergency brake light?
it sounds like the switch in back of emergency brake is bad or out of adjustment.the switch must be grounding out to make car quit. without looking at it, I would say it is the switch.
Mar 17, 2009 | 1998 Saturn SL
Mice ate transducer wire
cut the wire and re connect with crimp connectors and then seal withe heat shring tubing and a heat gun (put the tubing in first) or you could solder the ends together and heat shrink tubing over the individual wires. So long as you have a good water tight connection ther should be no adverse affects to your equipment.
Jul 30, 2008 | Lowrance Boating
Left side speakers only one working
Have you reset the settings in the system to 5.1?Are the rest of the speakers working? Go over the wireing yourself just unplug one at a time and reseat it on both ends system end and speaker end it may just be that when he put it together again one of the wires wasn't set back just right.
Jul 14, 2008 | Onkyo TX-DS676 Receiver
Microsoft Windows Vista Home Premium Edition for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
