Phillips Model 60pp920217f
Will my pictures color and clarity be any better if I change the Convergence IC's. I am expieriencing a green halo effect and also a double image of green at the bottom of the tv. The reds and blues seem to be all I get on the screen the rest of the colors are way off..like the yellows, whites and especially the greens....Will changing the ic's solve this problem?
  • tvproblemguy May 12, 2008
    Is this coolant hazardous..and what precautions should be used when changing it..... ? What about the letters outlined in green like there is a double image of words written above the original in green..Is this coolant issue also....My convergence lines are wavy and want align properly....
  • tvproblemguy May 20, 2008
    Does it matter what kind or brand of coolant you use?
  • 8,617 Answers
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
Posted on May 12, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    The green will appear similar to the convergence being out as the size of the green will be distorted due to the coolant. However if the red and blue are in alignment the convergence ics are fine. The coolant is glycol similar to automotive coolant it is hazardous to animals latex gloves would be recommended to .
  • Sonny Berry
    Sonny Berry May 20, 2008
    No it doesnt matter what Brand but is does have to be " Optical grade coolant for projection CRTs"
2 Suggested Answers
Bat1956
  • 585 Answers
SOURCE: Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 30, 2008
Is this a Convergence IC chip problem?
yes this is a bad ic
here is my tutorial.. most of these use a stk392-120 and i would replace both of them
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 14, 2010 | Philips 55PP9352 55" Projection Television
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Phillips magnavox 55" projection
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
Oct 14, 2008 | Televison & Video
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
My phillips model 60pp920217f
You may have to do the full convergence alignment for all three CRTs, as outlined in the service manual for your model. Do you have the full service manual for your set which outlines the alignment and convergence proceedures?
May 08, 2008 | Philips 43PP9202 43" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Phillips 60PP920217F Convergence Problems
Sounds like you are on the right track, yes you need to change also the return resistors, they will be located close to the convergence amps you have replaced. There should be several resistors standing up around the IC's, you can lift one leg and check all resistor and the ones with same color should be the same resistance. Another way is to just replace all of them. I don't have a location for you but I have replaced a similar set 51pp9303h/17 and I think the boards are similar. So if you are this close then by all means replace all the resistors, You can go to MCMelectronics, Bluestar-online.com, Tritronics, etc. To get part and also you can buy schmatics on line. Don't quite remember site but you can search. I think it was 11.99 for downloading for my set. So hope this helps.
Sep 19, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
