Question about Seagate (AU-80GBSATAHD) 160 GB SATA Hard Drive
I have momentus 5400.6 160 GB hard disk. How i am connect this hard disk with my pc by serial ata cable?
  • 11,800 Answers
Either just put it in an external case or use an adaptor if you want to install it permanently in your pc, the price is roughly the same.
Posted on Sep 05, 2010
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Have an i/o problem with Seagate Momentus 5400.3 ST9120822A - 120GB how can I solve it?
Hi burak02,
There could be a million reasons that your getting this i/o error. First I would check the cable to make sure it's snug on the pins, and then my suggestion is to follow this link HERE and pick the question that best describes what your OS and equipment list are. This is a great spot to solve most of the problems, They also have software you can download to test the drive to see if it's dead or just loose.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Oct 07, 2009 | Seagate Momentus 5400.3 ST9120822A - 120GB...
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
May 27, 2017 | Seagate Momentus 5400.3 Hard Drive
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Mar 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Seagate (AU-80GBSATAHD) 160 GB SATA Hard Drive Logo
85 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
