Question about Intel Motherboard
2 problems I can't fix
Starting up computer a box pops up which says (Resource file not found.) Then sometimes I can't continue on and have to shut down manually.
Another problem is the blue screen when I try to shut down the computer. It says (IRQL_NOT_LESS_OR_EQUAL)
I am definitely not an expert with computers, just the opposite. Can you help me.
C_spursdll
Posted on Jun 25, 2008
    Champion:
  • 230 Answers
You might have a corrupted hard drive. I suggest to back up all your data then reinstalling a fresh copy of windows.
Posted on May 12, 2008
Can I copy d partition from a bad hard drive that tested for 10 min before bad hard drive showed up in test
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now, start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
for USB drives click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then try copting your d partition
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
if you need more help with this post a reply
Hope this helps
Nov 06, 2012 | Computers & Internet
HP Digital Media Archive Pop UP
its been how long that u ahve been facing this problem
Apr 06, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
I have a Logitech quickcam E 2500. When making Video calls the picture freezes. Sound continues fine
This is a system resource problem.
Do the following maintenance on your computer to see if it is a simple resource problem or requires more complicated cleanup.
Use the Windows Disk Cleanup Tools:
  1. Click Start, Run and type cleanmgr.exe
  2. Click OK after the dialog box pops up with all of the items it wants to clean checked off.
  3. Do not run or click the option to Compress files
  1. Check your available disk space - Right click on the My Computer icon and select properties. The graph that comes on the screen should show more than 15% in pink.
  2. Run Defrag.exe from the accessories, system tools menu
If these simple things do not correct the problem your system will require a more complicated cleanup. Comment back if this is the case.
Apr 29, 2010 | Logitech Webcam
Photogallery pgm keeps popping up while working in any screen....will not cancel or can be identified in any programs or files in computer.....states that a CD/ROM application cannot be found when try
Download the Windows Installer CleanUp Utility which is free from here
  • Install the utility
  • Run the cleanup utility (usually found on the START / (ALL) PROGRAMS menu).
  • Scroll down until you see 'PhotoGallery'
  • Select Remove
  • Shut down the computer (not RESTART), wait 20-30 seconds, then power back up.
Reinstall Hp photo gallery if you still want to use it or need it.
Jun 01, 2009 | Compaq Presario Notebook
The setup file was stored on a network, it wasn't on your computer and now its trying to get it and it can't find it. you will have to get a copy of the file to your computer and then when it asks or the pop up comes you need to direct it to the file you got.
Mar 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Ressource files<C_SpURsDll>not found
Dec 16, 2008 | Computers & Internet
MONITOR
your computer is badly infected by virus, check system with a latest virus remover.
Nov 27, 2008 | Dell Dimension 2400 PC Desktop
Help
Sounds like the hard drive has been corrupted to where the autoexec.bat file can't be accessed. It is the main windows 95 start file that loads all drivers for basic function. May need to just cut losses on that unless you have a restore disk to reload win 95. Good luck with such an old system.
Mar 30, 2008 | Computers & Internet
THE FILE IS CORRUPT OR HAS BEEN ERASED THAT'S WHY
-> Click start > all programs > HP Application Recovery
-> When the Application Recovery console comes up, choose Application Installation then click NEXT.
-> When the list comes up, highlight Roxio DigitalMedia Archive by clicking on it, then click the "Install" button.
It should re-install Digital Media Archive, and fix your EZARC.msi search issue or problem.
I HOPE THIS HAD FIXED YOUR PROBLEM... ;)
Jan 10, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
well guyz... i got a solution... while u get the pop-up... open the task manager... and then search for the process DMASCHEDULAR
and end the process... it worked for me...
Feb 09, 2007 | HP Pavilion a1410n (ER890AA) PC Desktop
Intel Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
