Question about Refrigerators
I need a manual for a westinghouse fridge model RJ532
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Westinghouse RJ532, 530 Litre, Frost
sounds like the mechanism for the thermostat was compromised during the move
Posted on Mar 16, 2008
yalmer
  • 549 Answers
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
  • 57 Answers
SOURCE: HOW TO REPLACE DOOR SEALS IN RJ532 IT HAS NO
The model number you posted isn't coming up. But if there are no screws behind gasket and it is 5yr. or newer then it is a plug in gasket. Just pulls out.
Posted on Mar 31, 2011
I AM AFTER A MANUAL FOR MY WESTINGHOUSE 2 DOOR FROST FREE 517 LITRES REFRIDGERATOR MODEL RJ522V-R THANKS JULIE
Check the westinghouse web site. Many manufacturers publish user manuals for some products on their company websites..
Nov 13, 2015 | Westinghouse Refrigerators
Westinghouse fridge manual
If you have the model number, perhaps you or someone could find the manual online. No model number? good luck. You might try by model type on Westinghouse or other website. I hope this helps.
Feb 09, 2015 | Westinghouse Refrigerators
How do I set the temperature on my WSE6100SF fridge
Westinghouse manuals available for download from
http://www.westinghouse.co.nz/SupportCentre
Just enter your model number WSE6100SF and download the manual.
Sep 05, 2013 | Westinghouse Refrigerators
HOW TO REPLACE DOOR SEALS IN RJ532 IT HAS NO SCREWS FRIDGE SECTION
Mar 31, 2011 | Westinghouse Refrigerators
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
HI. I HAVE PURCHASED A SECOND HAND WESTINGHOUSE FRIDGE FREEZER. I WAS TOLD IT WAS MADE IN 1986. THE MODEL NO IS RS 615EA. CAN I FIND OR DOWNLOAD A MANUAL FOR THIS MODEL.
Hi, I can send you the service manual if you give me your email address. Unfortunately, I don't think you'll find the user manual for this model anywhere, unless someone has an old one lying around. The service manual has technical information and exploded views of fridge parts, wiring diagrams etc, and may be of some use. The service manual also includes other models, so you need to find your model in the service manual- it's about 57 pages long. Let me know if you want the service manual.
Mar 10, 2010 | Westinghouse Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
