Question about GE Ultrasonic 2.1 Speaker
I took my GE Multimedia 2.0 Speakers from my downstairs computer and plugged them into my Computer I have upstairs and the icon for the sound at the bottom right has the red X next to it. I went to i tand it's telling me there are no audio devices found. Help?
  • 835 Answers
Double click on your sound icon on the bottom of your screen. The one with the red x though it. If you do not see it their just simply go to your control panel on your computer.
In the control panel you will see a sound and audio device. Double click on that.
Then go to the sound tab, and click on it.
Under that you will see where you can select your audio devices. Click on the down arrows, chose the audio device you need, then click ok, restart your computer then you should be good to go.
Posted on Sep 05, 2010
My telephone connector is downstairs, and I want to have my PC upstairs - but I do not want to run wires around the house. Is there any way I can connect my computer wirelessly. i.e router downstairs,...
Yes, a wireless router should work fine.
You'll need a wireless-adapter (either internal PCI add-in card, or external USB stick) in your computer, if it does not have built-in wireless capability.
May 22, 2011 | Computers & Internet
My bose companion 2 series II speakers worked fine when they were first connected to my mac laptop. Then I disconnected it to take the laptop with me. When I plugged it in again it would not connect to the...
i noticed you mention an apple icon
is this computer an apple
have you tried selecting desktop speakers if there is that option
or maybe the drivers have been corrupted you might have to uninstall then reinstall either the sound device or the sound drivers
make sure you have them backed up to a disk before uninstalling them/anything
hope this helps
Dec 11, 2010 | Bose Companion 2 Series II Multimedia...
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
I moved our computyer from downstairs to upstairs.
Power supply is bad,,
You can try to unplug the main motherboard plug, then plug back in,, It should last as long as it stays pluged into the wall.
Keep it pluged in when you do this,,
Nov 30, 2009 | HP Compaq Presario SR1410NX PC Desktop
Cant connect to internet with main computer, one upstairs is fine
The upstairs computer is wired or wireless ?
If the upstairs computer is working then the router must be working properly.
Check the connection between the downstairs computer and the router.
If it is a wireless computer then check the wireless connection status on that computer.
Click Here for step by step solution
Nov 05, 2009 | Belkin Computers & Internet
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Mar 14, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Do not have owners manual
just hit the "int" button in the middle of the handset (above the number 2) and the display should read "Paging Extension?" so then you type in the handset of the other phone. For example, my base station is downstairs (Ext 1) and my other phone is upstairs. I pick up the upstairs phone hit "int", then "1" and the phone downstairs will ring. I believe they are, by default, set to "1" and "2".
Dec 29, 2007 | GE 28112EE2 Cordless Phone
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
GE Ultrasonic 2.1 Speaker Logo
138 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
