Question about NEC MultiSync VT480 Multimedia Projector
Bright yellow Whole screen took on bright yellow shade as if projector bulb was yellow, how do I get back to normal My problem is worse. I have a yellow, irregular shaped spot with a VT480...not the whole screen. Any ideas?
  • 1 more comment
  • keto1985 Jan 19, 2009
    i have got the same problem the whole screen is yellow u can still see whats on the computer screen throught the projector but my screen is yellow. i have changed the bulb as it was saying replace bulb and its still yellow. any ideas???
  • Anonymous Feb 03, 2009
    Hi i have the sames problem with my projector. in the end i found the problem. if tweaking with the display settings doesn't work then try the blue polarizer. it is this polarizer that made my screen go yellow it was broke. the polarizer is blue, inside the projecter there are 3 polarizers, blue, yellow and red. (ps not the little plastic filters)
    you can get a blue polarizer from nec 0208 4210 101 they are £10. iv just ordered mine.
    P.s. be sure to check the settings before buying and installing the polarizer, as this may be the cause.
    Also i have attached a pic of my polarizer to give a an example of what it looks like.
    Hope this helps
  • abeson Feb 09, 2009
    Did you get your replacement blue polarizer? If so, was it a success, and whet were the dimensions? I need to source a new filter for my PJ-TX200, but Hitachi don't list a part so if I can modify something I would be interested in trying.
Hi everyone i have the some yelow problem with CANON lv s3... any ideas where can i found this blue lcd polarizer...e-mail me sugestions jonasjhony84@hotmail.com
Posted on Mar 26, 2009
  • 563 Answers
Hi Badbear62
This is a blue LCD polarizer that needs replacement.
Posted on May 13, 2008
Yellow screen
my picture goes red shades and this means new bulb needed
sorry, but sounds like the same issue..... new bulb
I get hitachi with 3 year bulb warranty now for our school - cheaper in long run
Jan 22, 2013 | Philips Sony KDF55WF655 KDF55WF655 Lamp...
When i put a new bulb in my projector panasonic ptae1000 its shows green how do i fix this
A new bulb may just be showing up a problem that wasn't apparent with the lower brightness coming from an old bulb.
Try putting the old bulb back in and look very carefully and see if the problem is still there.
If the green is uniform over the whole screen then it may be fixed by setting a colour level change in the menu.
If it varies over the screen then it is probably a polarizer affected by age and heating.
Jul 14, 2011 | Panasonic PT-AE1000U LCD Projector
I have a 2004 Vauxhall Corsa C 1.4 SRi with Dull Headlights.
i have the same problem with my 54 plate corsa c i think its because the got the projector headlamps in and there is dust on the lens inside the headlamp,
i hav also tried puttin extra bright bulbs n and it makes it worse i cant see a thing
best bulbs i have found is genuine vauxhall or saab gm h7 bulbs
there normally about £8
regards johnyburrells mitsubishi and saab
Jan 19, 2010 | 2000 Acura Integra
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
3m projector color issue!
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll need to replace the whole optical engine.
Dec 15, 2008 | Office Equipment & Supplies
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Feb 26, 2008 | NEC VT676 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
NEC MultiSync VT480 Multimedia Projector Logo
2,295 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
