Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
What should the jumper setting be using a wd1600jb hard drive in an external case
  • 835 Answers
You should set it as master.
Posted on Sep 05, 2010
I have a Samsung SP2514N (250GB/7200rpm/8M/PATA) drive that I am trying to use as a USB drive on my laptop with Vista on it. The device manager shows that there is a drive there, but that is all. It does...
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
Feb 15, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
I using external CASE and connected in USB port.. but its detcting but it not shown in my computer.. i need anwswer plz.. is any JUMPER to place?
SATA drives do not have any jumpers.
If you were the one who mounted the EIDE drive into the external-case, be sure to set the jumper to "master" (not "slave", and not "cable-select").
Try connecting the external case to a different computer, to see if the unit works at all.
Remove the disk-drive from the case, and connect it as a "slave" disk-drive in some desktop computer, to see if it can be detected at all, when _not_ using the USB-to-Disk-Drive adapter.
Aug 19, 2010 | Seagate 25PK 160GB ST3160215AS SATA 7200...
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
External hard disk problem
Yes, it is very easy solution.
Just change your jumper settings, kindly set jumpers as a slave drive I assure that your Hard disk will be shown in drives.
Goo Luck
Nov 25, 2009 | Computers & Internet
Set the jumper to use the drive as e, external drive
There usually is no specific jumper. Just set it to "master" and it should work. The external enclosure supplies the appropriate host interface, so there will be no conflict with any other internal disk.
Oct 05, 2009 | Maxtor Hard Drive
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
What are the jumper settings when using Philips USB 2 0 3 5 inch
No Jumper Settings are required for external drives, they are all setup as Slave by default, and if you try to open the case, to take the drive out and change the Jumper Settings, you will invalidate the warranty.
Dec 23, 2008 | Computers & Internet
Installing an external drive
Check the jumper setting on the back of the hard drive and make sure it is set to master. You may also have to install the driver for your external case, should have came with and install cd
Jul 13, 2008 | Electronics - Others
Installation instructions and drives WD1600JB hard drive download please
not able to use disc that came with hard drive computer shows it's there but doesn't regester using as a second drive
Feb 15, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
466 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
