Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
HI I HAVE A PANASONIC TX-51P800H AND THE PICTURE KEEPS BECOMMING SLIGHLTY BLURRY AFTER ABOUT 5 MIN EACH TIME IT IS USED THAND WILL FIX ITSLEF AND REPEAT THIS EVERY COUPLE OF MINUTS.
SOURCE: My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Posted on Nov 05, 2008
asnowman
  • 788 Answers
SOURCE: blurry shaky pic
It sound like you have a leaky capacitor in your power supply, or video circuit, that is causing noise in the picture. I would have to refer you to a television technician in your area. This would seem like a simple repair. Leaky capacitors can become stable after they warm up.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Posted on May 01, 2009
  • 1039 Answers
SOURCE: My Panasonic PY 50LC13 shuts the picture down and
Check the lamp. see door on side.
Posted on Aug 29, 2009
  • 8457 Answers
SOURCE: MY PANASONIC 42
Ur power supply board is dying will be dead.Need anew board.
Posted on Sep 29, 2009
Slinteriors
  • 8617 Answers
SOURCE: My Panasonic Cinemavision 1080i PT53WX42F
IC4511 isnt comunicating. Replace the DG board
Posted on Oct 23, 2010
Hi I have a Panasonic LCD 32" and the following happens 1. I turn on TV and after 10-20 min it goes black screen and few second later it turns off 2. Red light blinks at one second intervals 3. I...
It may have unstable power supply due to bad DC filter caps, very common problem in ALL LCD TV's and monitors. You will need to do in-dpeth troubleshooting the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
May 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a Toshiba 65H82 and at first the picture was blurry but would clear up after about 10 mins now the picture just stays blurry. Can you tell me what the problem could be and if it is worth fixing it?...
Try adjusting the focus block this requires opening the back and front bezel of the TV. If it doesn't clear up after adjustment attempts then the liquid coolant inside each of the tubes need to be emptied and refilled with new coolant. Over time the coolant gets cloudy and can cause a blurry image with a white sheen. Contact me at the link below so I can help you further.....if this helps please rate:-)
Thank you:-)
http://tvtechwork.webs.com/
Oct 21, 2010 | Toshiba 65H82 65" Rear Projection...
BLUR PICTURES
Memory cards don't cause blurry pics. Is your lens clean? Is the lens extending properly?
Jun 23, 2010 | Panasonic Lumix DMC-FX50 Digital Camera
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
