Question about Amana ABB1927DE Bottom Freezer Refrigerator
The freezer is working the frig isn't
The freezer was working but the frig was not getting cold.....when you opened the freezer door cool air would flow into frig part....close door then no cool air....so I took the back part of freezer off and it is all iced over....is this major????????????
  • 1 more comment
  • Sandursky May 25, 2008
    We have the same problem, but the back of the freezer isn't iced all over.
  • Anonymous Jun 06, 2008
    The Amana timer was replaced but the problem remained.
    Any more suggestions?
    Hot in Virginia
  • Anonymous Jun 27, 2008
    the freezer sounds like water running when you close the door
Funny... I have the same problem. I took everything out of my fridge and looked into the two holes in the bottom and could see there was an ice build-up. I turned the cooling temperature to its lowest setting until the fridge shut off. Whammo! 30 minutes later my fridge was cool again and the ice had melted. WTF! Seems like it reset something. I had a service guy come anyway and I'll probably replace the two parts that he wants to b/c I don't want to go through that whole **** again. Let me know if it works for you. Could be a temp fix. It's going to cost a couple $$$ to get it fixed.
Posted on Aug 13, 2008
  • 975 Answers
YES , you need to replace the thermostat timer,its a device that operates like every 30 min or so applying heat thru a black element to keep the freezer from not building up ice . hope this helps AJ
Posted on May 12, 2008
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The frig... is not cold enought but the frezzer is working fine
Many refrigerators are cooled by a fan that delivers cold air from the freezer. Check to see if yours has this fan in the freezer compartment and if it is operating. It will be running whenever the freezer is calling for cooling, even when the door is open.
Jul 07, 2009 | GE Refrigerators
My fridge freezer comprises of the top one being the fridge and bottom is the freezer. its Zanussi by Electrolux . problem is the fridge is not functioning and its warm (its not cold at all) but freezer is...
It sounds like the fan in your freezer is not working so it can't get the cold air to the frig or your coils are not defrosting and it is stopped u and cant blow air into te frig, One way to check if you hear the fan and know that it is working open the frig and put your hand up near the vent to see if you can fill cold air if you can't now open the freezer door if you can feel the cold air or more air r coils then you could before then your coils are stoped up the unit is not defrosting.
Apr 03, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Estate refrigerator does not cool, but the freezer seems to work fine
open the frig door put youer hand over the vent comeing into the frig there should be cold air blowing with freezer door shut if not then opent the freezer door if you get cold air out of the vent now you have a defrost problem if you still have no cold air the damper door on that vent is not opening it will need to be replaced
Mar 27, 2009 | Estate Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore doors getting air vaccum and will not open right away
  • that is just a sign of a very cold freezer and a good sealed refrigerator.
  • if you don't like it then turn your freezer down so it wont get so cold.
Jun 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cooling
sure is you nailed it, behind the lower crisper drawer is air retunr make sure nothing covering those. removing back panel of freezer will also show problem, id assume iceis building up on either side. remove ive and refrig is restored. make sure doors are sealong sounds like warm aire getting in somehow
Feb 07, 2008 | Amana ABB1927DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
173 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
