Question about Sport & Outdoor - Others
Wiring diagram for Yamaha Speed and Fuel Management Meter 6Y8-Y8350-10-00
2 Suggested Answers
gregg201
  • 48582 Answers
SOURCE: 1981 Yamaha XJ650 Seca wiring diagram
Hi, Torrey for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1981 Yamaha XJ650 Seca wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XJ750 Owner Manual repair manual not owners
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Posted on Oct 14, 2017
2005 Grizzly display not working only back light comes on. ATV running great. Checked fuses with meter and checked voltage at fuses O.K.
Yamaha atv manuals
Yamaha ATV repair manuals
Hey Bruce,
get one of these manuals..they have the wiring diagrams and some troubleshooting tips.. trace the wires using the wiring diagram...take your time.. you CAN figure it out!!!
Sep 13, 2017 | ATVs
Wiring diagram
You can register on autozone's website and get access to basic repair info including wiring diagrams. The problem is going to be the wiring diagrams are filed under the component not the area of the car. So the fuel pump wiring is listed under fuel or engine management, the lights are under lights, and so on.
Jan 25, 2014 | 2000 Cadillac DeVille
Fuel pump relay wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yzf600r Fuel pump relay wiring diagram Google Search
1997 YZF600R BAD FUEL PUMP RELAY
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Jun 11, 2013 | 1999 Yamaha YZF 600 R thunder cat
Yamaha yellow engine warning light on YZF R125
Hi, Anonymous, if your ECU believed your engine was endangered of being damaged it would go into "LIMP" mode 5-10 mph only, it should be noted that the reasons your EFI light stays on constantly or flashes and your bike will or will not start and may turn over or not, these conditions will vary from bike to bike depending on the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work done to the bike or an abnormal event occurrence IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
how to reset engine management light
Yamaha Fault Codes
Yamaha YZF R125 Service Manual
YAMAHA YZF R125 Owner Manual
Mar 19, 2017 | Yamaha Motorcycles
Ybr125 cuts out at 7000 revs and engine management light flashes
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Fuel tank empty
10. Water or dirt in the fuel system, or clogged filter.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump.
13. Failed pressure regulator.
14. Faulty or clogged fuel injectors.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/23502-ybr-125-queries
YBR125 engine light
Yamaha YBR125ED 2005 Service Manual
Yamaha YBR125ESD Owner Manual
Mar 12, 2013 | 2007 Yamaha yBR 250
Yamaha vity wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha vity wiring diagram Google Search
Yamaha XC125 Service Manual
YAMAHA VITY XC125E Owner Manual
Sep 04, 2012 | 2009 Yamaha Vity
Where can I get a wiring diagram for the abs system to troubleshoot wheel sensors. Thank you Mark
Hi M, Turn the knob of your test meter to mili voltage. Remove the sensors one at a time and connect the cables to your meter. Pass a flat metal screw driver above (about a millimeter or closer, but not touching) and observe the meter. The meter will display a small voltage if it is working. The rotor mounted onto each wheel, as it turns generates an electrical charge. Just before lock up the charge drops, signaling the management system to momentarily release that brake. Regards John
Aug 30, 2012 | 2004 Nissan Frontier XE
2000 buick regal. Losing fuel pump voltage
http://www.bbbind.com/free_tsb.html free wiring diagrams ! Enter vehicle info. year , make , model an engine size . Under system click on engine ,then under subsystem click on fuel controls . Then click the search button , then click blue link .The 7th diagram down shows two fuel pump relays , This I have not seen before ! One is speed cont. relay an the other is just fuel pump relay ? The speed control one has a resistor in the electrical circuit . That is way your droping voltage .
Fuel Pump Electrical Circuit Diagnosis (VIN K)
Fuel Pump Electrical Circuit Diagnosis (VIN 1)
The PCM alters fuel pump speed by energizing the fuel pump speed control relay. Under normal conditions, the fuel pump speed control relay is energized. The applied voltage to the fuel pump is controlled by a resistor assembly. When higher fuel volume is required due to increased engine load, MAP sensor value over 90 kPa the PCM de-energizes the fuel pump speed control relay circuit. The increased voltage to the in-tank fuel pump allows a higher volume of fuel to be delivered to the fuel rail. The PCM also compensates for low system voltage by energizing the fuel pump speed control relay.
Have it check for codes !
Did DTC P0230 or DTC 1260 set?
Go to DTC P0230 Fuel Pump Relay Control Circuit or DTC P1260 Fuel Pump Speed Relay Control Circuit
Go to Step 3
May 05, 2017 | Buick Regal Cars & Trucks
I need the ignition wiring diagram of crux
You can see the wiring diagram in the service manual, which is free at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
You will have zoom in to read the wire colors.
Nov 13, 2009 | 2008 Yamaha Crux
Yamaha Neos Wiring/Electrical Diagram?
haynes are really brief, try speaking to a yamaha dealer, sometimes if you catch the on a good day they can send you a diagram they use, failing that you can purchase a manual on ebay normally, and failing alll that, work back bit for bit on all wiring with an electric meter
Aug 07, 2009 | 2002 Honda CR 250 R
Sport & Outdoor - Others Logo
205 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
