Question about Panasonic AG-DV2000 Mini DV VCR
AG-DV2000 Panasonic deck won't load small tapes. I've read the solutions posted. It seems to load OK then I see extra tape on the take-up reel side. Then I get a F11 code. Osvaldogusta said he adjusted the 'link transport mechanism'. Would this be of help. I do have the service manual, volume 1. I don't see that in the book. Any help is appreciated. Ed
    Champion:
  • 221 Answers
Abrsvcs is right - the takeup reel is not operating. The AG-DV2000 uses two direct drive reel motors - there are no belts or idlers. Check the ribbon cable connecting the takeup reel motor to the mechanical drive board; if this is OK, next suspect would be electrolytic capacitors on the drive board. You will need to remove the mechanism from the deck to check these.
Posted on May 14, 2008
  • 4,234 Answers
If you are seeing tape collect inside the unit, the takeup side is not functioning correctly. This may be as simple as a belt change or idler change. This is not a repair I would suggest that you start with. The alignment of the tape is critical to proper functioning. I would geuss that the "link support mech" is probably just the belt/idler assembly or it is a "mode" switch. In any case, this unit should be sent in for repair. As part of that repair, the conformance to industry standards.
Dan
Posted on May 12, 2008
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
Problem with playing large dv tapes
I am very familiar with these decks and I repair them. Contact my business Waveform Audio Video, Martinez, California. Email: waveform@wwdb.org
Paul
Oct 15, 2008 | Panasonic AG-DV2000 Mini DV VCR
DV Deck not loading tapes...wtf
most likely problem is a defective cassette housing. good service tech should be able to handle this with no problem.
Aug 29, 2008 | Panasonic AG-DV2000 Mini DV VCR
Relace mainboard in mini dv tape deck
what symptom does it have? describe what it is/isn't doing; most of the problems I've seen with AG-DV2000s are related to either defective capacitors on the mechanism drive board or dried grease on the reel table positioning arms. I've never had to replace a main board in a 2000.
Jan 02, 2008 | Panasonic AG-DV2000 Mini DV VCR
Panasonic dv2000
Cleaning is a good first step. If cleaning the deck doesn't work, it may need a tape path alignment.
Dec 27, 2007 | Panasonic AG-DV2000 Mini DV VCR
Panasonic AG-DV2000 Mini DV loading problem
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
AG-DV1000P that powers off when tape is put in.
hi sir one of the reel or capstain motors should be not allowing to work something prevents it from rotating check with hands for fluidity of capstain or reel motor that power off is a conclusion of a short while motor tries to spin check for any thing broken in the guides or the path regards please don't forget to rate ,thx
Mar 30, 2007 | Panasonic AG-DV1000 Mini DV VCR
Panasonic AG-DV2000 Mini DV VCR Logo
184 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
