Question about Toshiba COPIERS E-STUDIO 520 Copier
How do I move the finishing trays down? Toshiba estudio 520
    Sniper:
  • 66 Answers
There is a hole in the bottom of the finishing trays on the bottom left hand side (towards the back of the copier.) If you stick a slender object ie. screwdriver and then push towards the back of the machine it will release the tray lock and you will be able to slide the trays freely.
Posted on Sep 07, 2010
How to reset cdfo error toshiba estudio 355se
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
Oct 31, 2013 | Toshiba e-Studio 350 Copier
Toshiba estudio 161 don't change paper tray
THERE ISN'T PAPER IN TRAYS OR SWITCH OFF ON PANEL
Apr 28, 2012 | Toshiba Office Equipment & Supplies
Toshiba estudio 282 has error code cc90--how to reboot copier?
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
Apr 06, 2011 | Toshiba e-STUDIO 282 Black and White...
Toshiba estudio 45 error cc9
CC9 indicates Upper stack tray lift motor is abnormal on finisher MJ-1011. U need to check the wiring and sensors.
Oct 19, 2009 | Toshiba e-Studio163 Copier
CODE CD30
CD30 is an error code when there is an obstruction under the finisher trays. most of the time it is a garbage can preventing it from moving up and down properly
Jul 11, 2009 | Toshiba E-STUDIO 850 Copier
Automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
May 12, 2009 | Toshiba Estudio 200L Copier
Change default tray for E-studio 520
go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
Jul 25, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
103 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
