Question about Goodman Heating & Cooling
HOW TO READ THE MODEL NUMBER ON A GOODMAN A - COIL
2 Suggested Answers
  • 230 Answers
SOURCE: How do I clean the
Remove the cover in front of the coil, If the line set runs thru this cover try to slide it out of the way, some units have a triangle shaped sheet metal covering the end of the coil, if so remove.
The dirty side of the coil will be, on the air filter side of the coil, if the coil is very dirty use a vacuum with a with a brush and vacuum off the worst of the debris, some fins are soft so pay attention to them along the process. Using something like 409 and a pump up sprayer or squirt bottle spray the coil, start at the bottom and work your way up, this is so the water will drain into the drain pan.
When using the 409 and water watch that the water is not dripping into the furnace if so use a towel and or something to prevent the drips from getting into the furnace, take your time and be thorough.
Please buy a quality air filter, and prevent having to clean the coil again.
Posted on Jul 12, 2011
I have a model number and need to know how many BTUs.
Performance
Tonnage
2.5 Tons
Nominal Cooling Capacity
30000 BTU
Dimensions
Goodman CAPF3030B6 CAPF 2 5 Ton Upflow Downflow Coil Cased
Sep 19, 2017 | Optics
What do I replace my Goodman Model CPLE24-1C with
goodmans 2 ton. going any larger would require changing orfice and or coil.
Apr 11, 2014 | Goodman Heating & Cooling
Code A3 bad outdoor coil temp sensor
Need a model number for the outdoor unit. The sensor should have a part number tag on the sensor wire.
Dec 19, 2013 | Goodman Heating & Cooling
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
Run Capacitor is bad... what is the correct replacement number for model cple30-1c? Thanks
Look at the old capacitor. The rating should be printed on it. You just need to get one with the same microfarad rating. If you can't read it take the model # with you to heating and air supply that sells Goodman units and they should be able to help you.
Sep 01, 2010 | Goodman CKL42AR42 Air Conditioner
Please tell me the date of manufacture for Goodman CAP3636C6AA
You will need to post the serial number. The model number does tell me that you have a painted case, three ton coil with a fixed metering device installed, and it fits a 21" furnace or air handler. The first four numbers of the serial number will give the manufacturing date.
Oct 06, 2009 | Goodman GMS90703BXA Heater
I have a goodman 2 ton condeser model number CK24-18 and I was wondering if it would be could use a 10 SEER ADP UNCASED COIL R-22 2 TON?
Yes. The condenser is 1.5 ton and the larger coil will allow for better dehumidification but do not go any larger. Make sure when installed that bioth super heat and subcool are measured to insure proper charge and that system is working at peak performance.
Aug 14, 2009 | Goodman Heating & Cooling
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Heating & Cooling Logo
169 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
