Question about RCA L46WD22 Television
HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
I purchased a RCA L42WD22 Flat panel TV. I hooked up an HDMI cable and have picture - I do not have sound. I've read the only fix is to take to repair shop. Is there an alternate solution. Thank you.
  • 3 more comments
  • Cassius98 May 22, 2008
    9 months old NO SOUND. did software upgrade no help. closest repair center over 2 hours away. any help would be appreciated.
  • dlevans Dec 14, 2008
    can you tell me were the board is located and what component it is. I do have experience with soldering and electronics. Thanks danny
  • rpsokel Dec 18, 2008
    i have the same problem. i have had the tv for just over a year and the sound all of a sudden doesn't work, nor does the side av jacks where i plug my playstation into. sounds like a bad board and/or connection inside the tv to me, but i don't want to pull anything apart without any assistance.
  • Anonymous Mar 18, 2014
    un55eh6030
  • Anonymous Mar 31, 2014
    Sanyo model# dp58d33 and RCA
    Genius:
  • 1,030 Answers
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
Posted on Jun 10, 2008
No solution, but same problem here as rpsokel; PS3 audio/visual suddenly no works and no sound on TV cabel channels; all occured at once.
Posted on Feb 22, 2011
HDMI I have no sound when hooking up my HDMI(cable output) to DVI.
DVI does not pass audio to the HDMI cable. You must use an audio cable (red & white RCA connector) for the TV
Sep 23, 2014 | LG 32LX4DC 32 in. LCD Television
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
I HAVECONNECTED ALL MY SPEAKER WIRES,HDMI CABLEAND CONNECTED THE YELLOW AUDIO CABLE.POWERED UP THE DVD BOX BUT I ONLY GET SOUND FROM TV.the tv is a new 47'' LG.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
Jan 01, 2011 | Televison & Video
I have a toshiba 42HL196. With HDMI cables hooked up, I have no picture when attempting to watch cable TV or use my DVD player. Everything works when I hook up using RCA cables. What is my problem?
By no picture, do you mean that you have sound? If yes then ensure that the tv and the DVD player/cable box is set to the same resolution as that of the tv. That should resolve the problem.
Dec 04, 2010 | Toshiba 42HL196 42 in. LCD HDTV
My sound just went out and the picture is fine
Be sure the speakers are "on" on the menu......un plug it and your cable or sat reciever for a bit and re start them both. Lastly see if problem still there on a dvd player........if so............it may need a main board. You may be able to circuimvent by getting sound thru a surround or amplified spkr set up and hook to your cable or sat reciever too
Jun 04, 2010 | RCA L42WD22 42 in. LCD Television
My flat screen tv/dvd combo has sound but no picture... but when we put a dvd in there, it does show a picture! What could be wrong??? Help!
If u able to have picture watching a dvd,than it not ur tv is the problems.Ur tv connected to a cable,satalite or a Telicom boxes?Unplug,replug these boxes about an hour later,let it reset it self,upgrade it software.Ur tv should have it picture back.
May 21, 2010 | RCA L42WD22 42 in. LCD Television
Sold as HD Ready, but hopw do I connect HDMI to it to get HD picture ?
to hook hdmi to it you need to purchase a hdmi cable and plug it into the tv and then into what ever you want for example like your cable box,dvd player,etc.once hooked up turn tv to hdmi input
May 31, 2009 | Panasonic Televison & Video
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
RCA L46WD22 Television Logo
712 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
