Question about Microsoft Windows XP Home Edition
I installed 'speed up your PC' by Uniblue and now my windows XP PC continually reboots to the advanced menu page where you have the option of a safe start, revert to previous settings and normal start. Whichever option I select just reboots the PC back to the same screen. I have been advised to re-install my directory and that I can use a Bart PE boot CD to help. Is this the case and how do I go about installing any software on a machine that continually reboots and never actually starts?
  • 560 Answers
Yes, you can use a Bart PE Boot CD. I've used it several times to do many repairs , even blue screens and fatal errors . Follow the steps exactly as I'm going to list them for you . (Before starting this, make sure the BART disk is already in the computer CD Drive. Don't worry if it spins up...It will load when you complete the following steps.) Also, be sure you are not connected to the Internet and if you have a wireless connection , disable it as you do not want to access the Internet while doing the repairs to your computer's XP system files .
1. from computer startup, press F1 or whatever keys to press to access your BIOS / CMOS utility screens to select "Boot Sequence" to change your boot device options to first boot device is CD ROM. Sometimes it will be the F12 key at startup to change "Boot Order"
Regardless the procedure you'll use , the the end result is that the CD Boots FIRST. Save changes and exit, usually by missing F10 if in BIOS. Regardless, we want the computer to boot the CD Drive from power ON.
2. Once the computer reboots from the CD ROM , be patient and don't press any keys while BART loads its files and applications .It will display several screens while loading up . The last task screen it will display should be the network support attempt to connect screen . After the program realizes there is no Internet network connection , it will display its inability to connect . Then the computer screen should look similar to the default XP desktop display.
3.left click your mouse on start (lower left of the screen ) . Several applications and tools will appear on the list . Scroll up to disk tools and select it or highlight it until the disk tools options appear . Select check disk . You'll notice two or three check disk options . Select the one that just says check disk. Left click on it to start the application . If you have selected the right one it will display a menu of options beginning with which drive you want a check and you will manually enter your C drive as per the exaple it shows. Then, it will prompt you for two specific details you will have to decide on. I don't remember the exact wording, however, I can tell you what you want to select . Select the " /r " (repair) option for sure. Also, select the thorough check option that "takes longer" to complete but recovers lost data and repairs clusters and sectors . Be sure to take your time and confirm your selections as required before the check disk application starts .
4. Once it starts to run , don't touch the computer . It may take awhile to complete the task . I've seen it take as long as 60 minutes to complete . Regardless , once it is finished it will display the details of what it found wrong and what it repaired If there were any problems or system errors on the hard drive . If it displays that it found errors and corrected them , close the application , THEN REMOVE THE CD , and finally, use the the standard shutdown procedures you normally use and select Restart.
5. Dont worry about the boot sequence , as it will default to your C: drive (hard drive) after it fails to boot from the CD ROM .
6. Hopefully, your computer will start and run normally .
7. If it doesn't , repeat the Bart CD loading procedure and try some of the other options available , such as the registry checker , etc. however , be very careful how you use the Bart disk tools as some of them are complicated to use and can cause irreversible hard drive failure if not properly run . Be careful . The check disk option has worked for me 80% of the time without having to do anything else . Good luck
Posted on Sep 05, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
COMPUTER GETS REBOOTED IN THE MIDDLE AUTOMATICALLY
Try this:
Reboot you PC into SAFE WITH NETWORKING:
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu".Use your arrow keys to move to "Safe Mode With Networking" and press your Enter key.
To get into the Windows Vista and Windows 7 Safe Mode With Networking, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu"Use your arrow keys to move to "Safe Mode WithNetworking" and press your Enter key.
Log into the Administrator account(password may be rquired)
Once you're in Safe mode with networking download:
rkill.exe save to your desktop and double click.A command prompt window will flash and its done.
Then download Malwarbytes:
http://www.bleepingcomputer.com/download/malwarebytes-anti-malware/dl/7/
Once Malwarebytes has been installed run a full scan
How to run a Full scan with Malwarebytes:
https://lbis.kenyon.edu/helpline/antivirus/malware_scan
Note:
If your PC does not shut down in safe mode it sounds like Malware.
Aug 10, 2012 | Compaq Presario 2170US Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Cant activate windows xp home edition
Hi
Try and see what the BSOD says , when it suddenly reboots. Press F8 until it gives you a menu , go to advanced options or something similar highlight don't reboot or restart automatically.
Can you start your PC in safe mode. Try a crack although I wouldn't recommend it.
May 24, 2010 | Microsoft Windows XP Home Edition
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
How do i reboot in safe mode
HI,
Follow this steps:
  1. Restart your computer.
  2. When the machine first starts again it will generally list some equipment that is installed in your machine, amount of memory, hard drives installed etc. At this point you should gently tap the F8 key repeatedly until you are presented with a Windows XP Advanced Options menu.
  3. Select the option for Safe Mode using the arrow keys.
  4. Then press enter on your keyboard to boot into Safe Mode.
  5. Do whatever tasks you require and when you are done reboot to boot back into normal mode.
I Hope it helped.
Jan 24, 2010 | Toshiba Satellite A300-0CF035 Notebook
I brought my hp about 2 years ago it worked for about a month now im trying to fix it but when it comes on it goes to the screen where it asksstart windows normally how do i reboot
You can choose to start windows normally and it should bring you to regular desktop. If not to reboot you actually have to shut it off by holding down power button until it shuts off. If still issue try to boot in to safe mode by pressing F8key on boot up and keep on pressing it till advanced start up comes up. Once in safe mode try to run virus scan to see is there any viruses. Also in same menu there is safe mode with networking if you choose this one you can do updates since it will allow you to go online even that you are in safe mode. This might resolve the issue.Hope this helps.
Jan 16, 2010 | HP Compaq Presario SR2150NX PC Desktop
Can't boot windows xp
  1. I believe your talking about Windows XP
  1. Restart your computer and start pressing the F8 key on your keyboard.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom.
  4. try that and see it works.
  5. if so reboot and then use the last known configuration option.
Nov 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
LAPTOP IS ON SAFE MODE AND I DO NOT KNOW HOW TO GET IT OFF SAFE M
when switching on your laptop please tap F8 key continuously and it should take you to the boot options
Sep 10, 2009 | HP Pavilion dv9000z Notebook
How to start in safe mode
Windows XP and Vista
Using the F8 Method:
  2. When the machine first starts again it will generally list some equipment that is installed in your machine, amount of memory, hard drives installed etc. At this point you should gently tap the F8 key repeatedly until you are presented with a Advanced Options menu.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
Microsoft Windows XP Home Edition Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
