Question about Maytag 25.1 cu. ft. Bottom Freezer Refrigerator with Factory-Installed Ice Maker
Replace ice maker in mfi2568aeq
Need help with extracting old ice maker to install a new one
4 Suggested Answers
SOURCE: MFI2568AEQ
i fixed the problem with my fridge i hope it will work with everyone best of all at no cost unplug the fridge and plug it back in do this four times back to back leave it pluged in on the fourth time and then hold the light and lock button for three seconds it seems to reset and work fine i hope this is a cure and would really like to know if this helps vulcanv88@aol.com
Posted on Aug 01, 2007
bestdarngood
  • 3037 Answers
SOURCE: ice maker does not work
This is a quite common occurrence. You just have an ice build up in the ice maker. Make sure the prongs are vertical in the ice maker and defrost the freezer and dry it out and you should have it working again, it not let me know and there is something else we can do.
Please let me know how this works out though
A quick fix is to take a hair dryer to the ice maker but it may freeze up right away again so its best to defrost it.
good luck
Posted on May 22, 2008
  • 3289 Answers
SOURCE: The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Posted on Jun 18, 2010
How do you change out a maytag ice maker model number MFI2568AEQ? Have everything apart but wireing harnes iswholding it in and cant get my fingers in to seperate it
If you are trying to unplug the harness from the ice maker housing, take a small screwdriver and press in on the tab that locks the harness into the ice maker. If you are trying to remove the harness from the back or side wall, there is a small tab on the side of the plug that needs to be pulled out to unlock it.
Sep 30, 2010 | Maytag Freezers
Ice maker does not work
When this happens usually you need to replace the solenoid activating the water filler
May 22, 2008 | Maytag MSD2651 HE Side by Side...
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Apr 07, 2010 | Amana AFD2535DES French Door Refrigerator
Wont make ice
For the moment I would like you to fill the ice maker with tap water unless the cubes are stuck there. Most times the water control valve on the rear are the problem. One side feeds the dispenser and the other feeds the ice maker. Model number Y13068002 Let me know if it will drop ice after filling tray with water. If not the focus will be on the ice maker. During that time I will get you a service manual if correct model number and a place to find parts to get yu going again, Thanks, Se Breeze
Jan 15, 2010 | Refrigerators
I have a Kenmore side by side elite. I have installed a new ice maker. I can not get water into the ice maker. The extraction teeth rotate and I get water through the water port on the door but not into...
Usually happends that the solenoid (electric valve who opends when the ice maker calls for water) leaks and this water freezes up inside the filling tube for the ice maker , t he solenoid has to be replaced.
Sep 20, 2009 | Refrigerators
I have a Kenmore side by side refer, model# 106.54682300. The ice maker fills and freezes the ice without issue. But, it will not extract the ice from the tray. It extracts the ice only partially and...
I believe the heater element beneath the ice maker is burned out. It always comes on just before the ice maker dumps the ice into the tray/storage. The parts are available but the problem is it will cost half as much to replace the parts as it would to replace it with a new one. If you want to do this I will help you so please let me know. Or if you need help in finding the problem I will help you. Just tell me what you would like to do. Thanks, Sea Breeze
Aug 11, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Ice maker doesn't work
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Oct 07, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
96 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
