Hi.. i have an idea handset. But whenever i try to connect to idea wap with the default idea settings then it gives an error as "PACKET DATA CONNECTION NOT AVAILABLE". Could u assist me a solution to this problem plz..
Send me wap seting in to 9592697032
Posted on Feb 11, 2011
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
Mms/gprs settings.my network provider is smart
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Jun 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I have Nokia Nuron 5320. It keeps on giving me this message: Application error. Application will now close. This is when I am in the middle of using the phone. I do not have any internet service and...
Hi
Call the customer service and the Internet setting in your Handset, bcoz your handset is not configure for Internet and when you hold the ETC key the internet is start for browsing, but your internet setting is not configure then you get the application error.....
cheer
Jun 04, 2011 | Nokia 5230 Cell Phone
Hi i have a nokia 6300 which used to be an old vodafone. i am using it on o2 and have no problem connecting to wap or sending messages. however when i try to access skype i get error message "subribe...
hi there, In this case you need to contact your network provider so they could send you the settings so you could use the service. hope this one helps.
May 18, 2011 | Nokia 6300 Cell Phone
AFTER LOADING THE SETTINGS SENT BY AIRTEL WE TRIED CONNECTING TO NET BUT GET AN ERROR MESSAGE - PACKET DATA CONNECTION NOT AVAILABLE
Saving WAP/Internet settings is sometimes not enough. you may also need to make that APN your default APN for browsing. This is found usually under settings> Connections (or something like that depending on the make of the phone) then access points or browser settings. Some phones you can access it by opening the browser and hitting options then settings and access point. Failing that, make sure you dont have any data barring on your service.
Dec 10, 2010 | Cell Phones
Subscribe to packet data first..
Here is what to do : In opera mini check what type of connection is been set . There are to types [HTTP , SOCKET] . Just try to switch between them and you'll solve the problem . For me [SOCKET] is always better , because [HTTP] takes long time to load a page . If that didn't solve the problem , then in the phone , go to SETTINGS and make sure that all applications are allowed to use your preferred access point as default for Applications .
your rating is very important for me , that's why I've helped you .
good luck .
May 11, 2009 | Nokia 6300 Cellular Phone
I have bpl sim card,i want to know setting for using wap internet on my mobile 5300
Hi i was reading regarding WAP settings for BPL mobile...I have copied and pasted what i saw from different forums...see if it is of any help
you can manually conigure GPRS in your mobile phones.
BPL_WAP
homepage http://wap.mizone.bplmobile.om
Session mode permanent
connection security off
data bearer gprs
gprs access point mizone
IP address 10.0.0.10
authentication type normal
login type automatic
BPL_MMS
data bearer gprs
For those who are interested in using GPRS facility provided by BPL Mobile (Mumbai only) here are the brief n settings required for it. You can also use this for surfing Internet through you PC provided your PC is connected to your mobile using Data Cable or preferably BlueTooth.
Go to the main menu and open “Settings”
Select “Configuration” and then “Personal Configuration Settings”. Create a new configuration settings by selecting “Add New” from “Options”
The account fields should be filled as below:
Account Settings Account Name : bplweb
HomePage : http://wap.mizone.bplmobile.com
User Name : Your mobile number
Password : bplmmsc
Use Preferred access point : No
Access point settings : As given below
Access point settings Proxy : Enabled
Proxy Address : 10.0.0.10
Proxy port : 9401
Data bearer : Packet data
Bearer settings : As given below
Bearer settings Packet data access point : mizone
network type : IPv4
Authentication type : Normal
Password : bplmmsc
Now once you have done that get back to “Personal Configuration Settings” select the new account “Bplweb” that you have just created and go to “Options” and click on “Activate”
Go back to the main menu and open “Settings”
Select “Connectivity” and then “Packet Data”
Set the “Packet data connection” to “When needed” and then click on “Packet Data Settings” then “Edit active access point” and then set “Packet Data Access Point” to bplgprs.com
These instructions are according to the Nokia sets 3110c, 6085 and should not differ much for other sets and brands and in case of which you can always go to the customer care as did.
BPL WAP SETTINGS FOR MOBILE PHONES
Connection name:- BPL WAP
data bearer: packet data
Access point name: mizone
User name: 919821099800
Prompt password: no
Password: bplmssc
Authentication: normal
Homepage: http://wap.mizone.bplmobile.com/
ADVANCED SETTINGS
network type: IPv4
Phone IP address: automatic
DNS address: automatic
Proxy server address : 10.0.0.10
Proxy port address : 9401
Hope this helps !!!
Apr 17, 2009 | Cell Phones
Gprs not working on my nokia n72
Dear Mikunj
First of all the error u have said is occur due if there is no proper setting or packet data not available
So first subscribe packet data from your service provider they will send you gprs setting via message,save it then long press 0 key to start gprs (wap) page
Now most of service provider gives free surfing to gprs,so check it with customer care
but if you have already have subscribed packet data & have gprs setting in ur phone & still problem occurs then ur phone's certificates has been corrupted & u have to reinstall it
Thanks
Mar 10, 2009 | Nokia N72 Cellular Phone
Gprs not working on nokia n72
Try this link to setup the configuration for the internet on your phone:
https://nokiags.wdsglobal.com/standard?siteLanguageId=118
How can i open my GPRS?
hello..
please try to manually configure your browser settings with this one..
Prompt password: No
Network type IPv4
Prompt p’word: No
II. MMS Settings
Access point: mms
Prompt password: No
Network type IPv4
Access point: mms
Prompt p’word: No
hope it helps..
Jan 08, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
