Question about Zebra Stripe S600 Thermal Label Printer
Continuous feed When I turn on the S400 it goes through the self test and then just starts to feed labels.
It has been my experience this can be caused by the labels not being loaded correctly. Doubel check the labels are feeding through the lower sensor. It looks like a small arm under the large plastic piece under the front small rollers.
Posted on Jun 19, 2008
    Novelist:
  • 170 Answers
Sounds to me like it could very well be a faulty clutch in the feed assembly...The clutch mechanism is like a measureing tape and if it goes bad and fails to actuate at the right time then either it's connection to the board nedds reseating or the spring loaded flapper got bumped out of place, the spring fell off or broke or you just have a bad clutch thats not working anymore... check for this first...
Posted on May 12, 2008
How to I feed the labels into the zebrastripe printer s400 series
unter the withe roller, between the sensors thougnt printhead. the ribbon have to be on tope the sensors, not same path as paper otherwise, will come with no ribbon error.
Nov 21, 2013 | Zebra Stripe S400 Label Printer
How to restore default configuration
From the user manual:Feed and Pause self testperforming this self test temporarily resets the printer configuration to the factory default values. these values are active only until power is turned off unless you save them permanently in memory. If the factory default values are permanently save, a media calibration procedure must be performed.To perform a Feed and Pause self test, complete these steps:1. Turn off (O) the printer.2. Press and hold FEED and PAUSE while turning the power On (I)3. Hold FEED and PAUSE util the first control panel light turns off.the printer configuration is temporarily reset to the factory default values. No labels print at the end of this test.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
My label starts printing halfway down the label
hi,
1. Check the printer settings of the software you are printing with.[most
probable cause]
cause]]
2. Turn off printer.
Open the printer and remove the labels roll.Re-load it and close the printer.
Press and hold the feed button.
Power on the printer and release button after first flash of led light.
Printer will self test.
Turn it off and on again.
Now print.
good luck!
Sep 09, 2011 | Zebra Z4Mplus Label Printer
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
LIGHTS ON PRINTER LOCKED UP
Try a reset: press the PAUSE and FEED buttons and turn the printer, release the keys when label feed.
Jan 19, 2009 | Zebra Stripe S400 Label Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Not printing the correct text / picture
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
219 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
